FreeNAS 11.1u2 - zfs + nfs hang requiring reboot
segfault
Every few weeks since upgrading to 11.1 I've encountered random zfs+nfs hangs. These appear to be due to locks. When I say hang I mean the server no longer responds all clients (freebsd, linux, esxi) enter iowait until the box is rebooted.
PID TID COMM TDNAME KSTACK
2753 102815 nfsd nfsd: master mi_switch sleepq_wait _sleep svc_run nfsrvd_nfsd nfssvc_nfsd sys_nfssvc amd64_syscall Xfast_syscall
2753 102883 nfsd nfsd: service mi_switch sleepq_wait sleeplk __lockmgr_args lockmgr_lock_fast_path VOP_LOCK1_APV _vn_lock zfs_fhtovp nfsvno_fhtovp nfsd_fhtovp nfsrvd_dorpc nfssvc_pro
2753 102884 nfsd nfsd: service mi_switch sleepq_wait sleeplk __lockmgr_args lockmgr_lock_fast_path VOP_LOCK1_APV _vn_lock vget cache_lookup vfs_cache_lookup VOP_LOOKUP_APV lookup nfs
2753 102885 nfsd nfsd: service mi_switch sleepq_wait sleeplk __lockmgr_args lockmgr_lock_fast_path VOP_LOCK1_APV _vn_lock zfs_fhtovp nfsvno_fhtovp nfsd_fhtovp nfsrvd_dorpc nfssvc_pro
2753 102886 nfsd nfsd: service mi_switch sleepq_wait sleeplk __lockmgr_args lockmgr_lock_fast_path VOP_LOCK1_APV _vn_lock zfs_fhtovp nfsvno_fhtovp nfsd_fhtovp nfsrvd_dorpc
D
dlavigne
Guest
Hardware specs?
Also, anything in /var/log/messages around the time of the hang?
segfault
Hardware specs?
Dell R710
2x Intel(R) Xeon(R) CPU X5650 @ 2.67GHz
76gb 10600R ecc ram
2x LSI Logic / Symbios Logic SAS2008 PCI-Express Fusion-MPT SAS-2 [Falcon] (rev 03)
ConnectX-3 Pro
dell compellent hb-1235
Three raidz2 vdevs.
There is nothing logged. I've got some procstat output. I wish I had some dtrace scripts to count the locks involved...
segfault
The system itself remains responsive to both web and ssh traffic but refuses to respond to any nfs requests. Attempting to restart nfsd or kill it results in a hung console.
segfault
Here's a bit of the /var/log/messages log file from right before I rebooted it.
Mar 30 09:49:50 freenas mountd[2748]: export request succeeded from 192.168.1.36
Mar 30 09:49:52 freenas mountd[2748]: export request succeeded from 192.168.1.36
Mar 30 09:50:00 freenas mountd[2748]: export request succeeded from 192.168.1.36
Mar 30 09:50:02 freenas mountd[2748]: export request succeeded from 192.168.1.36
Mar 30 09:50:10 freenas mountd[2748]: export request succeeded from 192.168.1.36
Mar 30 09:50:34 freenas daemon[4250]: 2018/03/30 09:50:34 [WARN] agent: Check 'freenas_health' is now warning
Mar 30 09:52:34 freenas daemon[4250]: 2018/03/30 09:52:34 [WARN] agent: Check 'freenas_health' is now warning
Mar 30 09:54:06 freenas uwsgi: GSSAPI Error: Miscellaneous failure (see text)MORDOR (unable to reach any KDC in realm MORDOR)
Mar 30 09:54:34 freenas daemon[4250]: 2018/03/30 09:54:34 [WARN] agent: Check 'freenas_health' is now warning
Mar 30 09:56:35 freenas daemon[4250]: 2018/03/30 09:56:35 [WARN] agent: Check 'freenas_health' is now warning
Mar 30 09:58:35 freenas daemon[4250]: 2018/03/30 09:58:35 [WARN] agent: Check 'freenas_health' is now warning
Mar 30 10:00:35 freenas daemon[4250]: 2018/03/30 10:00:35 [WARN] agent: Check 'freenas_health' is now warning
Mar 30 10:02:36 freenas daemon[4250]: 2018/03/30 10:02:36 [WARN] agent: Check 'freenas_health' is now warning
Mar 30 10:04:36 freenas daemon[4250]: 2018/03/30 10:04:36 [WARN] agent: Check 'freenas_health' is now warning
Mar 30 10:06:16 freenas shutdown: reboot by segfault:
Mar 30 10:06:17 freenas devd: notify_clients: send() failed; dropping unresponsive client
Mar 30 10:06:19 freenas kernel: epair0a: link state changed to DOWN
Mar 30 10:06:19 freenas kernel: epair0b: link state changed to DOWN
D
dlavigne
Guest
Try updating to U4 to see if that resolves it. If it doesn't, it's worth reporting at bugs.freenas.org so a dev can help pinpoint the issue. Post the issue number here if you create one.
segfault
Ok, I'll file a bug. I don't see anything in the U4 changelog that touches where these locks are.
D
dlavigne
Guest
The dev will want to use U4 as the base. There were some performance/resource fixes between U2 and U4.
