FN11 postinit script not working
Grewterd
I have a postinit script that I setup in FN9 to email me the boot log when the system starts. This is not longer working on FN11. Has anyone else had this experience?
I have it setup as a command running a .sh script.
Thanks.
Doesn't that replicate most/all of the security run email you'd get anyway after rebooting?
Grewterd
dlavigne:
I could not find anything referencing the script in either of the log files.
Ericloewe:
I don't know, I don't get any email after rebooting. Just tested, no email from this script or at all after reboot.
Maybe I'll rewrite in Perl and use sendmail to learn more Perl (I'm a bit off my path because of CISSP bootcamp at work is taking all my reading time now, I had most of the smart report re-written, well the hard parts).
Stux
Thanks.
Are you running it via full path?
Spearfoot
He of the long foot
Sounds like your script is executing just fine: it just doesn't send the email message you're expecting. Try modifying the script, adding code to echo the date or other text to a log file, then execute it. You can check the log file to see what's happening. This will help determine whether or not the script is actually running.
If you determine for a fact that it is running, but just not sending an email, then you know to debug the script itself instead of investigating FreeNAS Init/Shutdown Script support.
Stux
Which is exactly why my start_fan_controller script starts with
#!/bin/bash
echo "Starting Hybrid Fan Controller..."
/mnt/tank/server/scripts/hybrid_fan_controller.pl &>> /mnt/tank/server/logs/fan_control.log &
It appears nicely in the log as it pushes the fan controller into the background.
