I'm trying to update my firmware to 9.1.1 using GUI Upgrade on my MicroServer N36L.
Current Build: FreeNAS-8.3.1-RELEASE-p2-x64 (r12686+b770da6_dirty)
I'm using the following file to update: FreeNAS-9.1.1-RELEASE-x64.GUI_Upgrade.txz
The update process completed the 2 steps and reboots, but after reboot the firmware is still 8.3.1. I checked /var/log/messages and couldn't find anything.
I checked the /data folder and found the following in update.failed file:
[root@freenas ~]# cd /data
[root@freenas /data]# ls -lrt
total 2484
-rw-r----- 1 root wheel 171008 May 5 2012 factory-v1.db
drwxrwxr-x 2 root operator 512 May 5 2012 .snap
drwxr-xr-x 2 root wheel 512 May 18 2012 ssh
-rw-r--r-- 1 root wheel 867960 Dec 17 16:02 rrd_dir.tar.bz2
-rw-r--r-- 1 root wheel 34 Dec 17 16:05 update.failed
drwxr-xr-x 2 root wheel 512 Dec 17 16:08 zfs
-rw-r----- 1 root operator 217088 Dec 17 16:46 freenas-v1.db
[root@freenas /data]# cat update.failed
ValueError: hour must be in 0..23
Any suggestions on what I can do to fix this error? Or am I looking in the wrong place?
Thanks!
total 2484
Thanks!
