volandir
 - Sep 21, 2013
Yesterday I installed Firefly plugin. It went easy and iTunes attached to my FreeNAS. The problem was Firefly doesn't seem to work with FLAC files. I found the sample config file "mt-daapd.conf.sample" and according to it I added the following lines to "Auxiliary parameters" section of Firefly GUI configuration:
Can someone help?
			[general]
ssc_codectypes = ogg,flac
ssc_prog = /usr/pbi/firefly-amd64/bin/mt-daapd-ssc.sh
Then between the multiple restarts all of a sudden I was able to play one of the FLAC files. Regrettably I restarted Firefly to be sure it's OK and FLAC transcoding was not working. I wasn't able to repeat my success anymore.Can someone help?
