Firefly initiating scan of over 15,000 music tracks.
Using 8.3.0 x64 with associated firefly plugin.
Hardware: HP Proliant Microserver with 8GB RAM and 4 x 2TB Drives, each with 2GB of Swap space.
mt-daapd.log
Is there a way of constraining the maximum memory utilisation of the firefly daemon?
mt-daapd.log
2013-01-07 18:19:55 (18a217af): Firefly Version svn-1696: Starting with debuglevel 2 2013-01-07 18:19:55 (18a217af): Error opening plugin dir /usr/lib/firefly/plugins. Ignoring 2013-01-07 18:19:55 (18a217af): Error opening plugin dir /usr/lib/mt-daapd/plugins. Ignoring 2013-01-07 18:19:55 (18a217af): Error opening plugin dir /lib/mt-daapd/plugins. Ignoring 2013-01-07 18:19:55 (18a217af): Error opening plugin dir /lib/mt-daapd/plugins. Ignoring 2013-01-07 18:19:55 (18a217af): Error loading plugin /usr/local/lib/mt-daapd/plugins/ssc-script.so: plugin declined to load 2013-01-07 18:19:55 (18a217af): Plugin loaded: rsp/svn-1696 2013-01-07 18:19:55 (18a217af): Plugin loaded: daap/svn-1696 2013-01-07 18:19:55 (18a217af): Starting rendezvous daemon 2013-01-07 18:19:55 (18a217af): Starting signal handler 2013-01-07 18:19:55 (18a217af): Error: enum_begin failed (error 1): Misc SQL Error: no such table: config 2013-01-07 18:19:55 (18a217af): Can't get db version. New database? 2013-01-07 18:19:55 (18a217af): Initializing database 2013-01-07 18:19:55 (18a217af): Error: enum_begin failed (error 1): ? 2013-01-07 18:19:55 (18a217af): Error: enum_begin failed (error 1): ? 2013-01-07 18:19:55 (18a217af): Full reload... 2013-01-07 18:19:56 (18a217af): Starting mp3 scan 2013-01-07 18:19:56 (18a217af): opendir: No such file or directory 2013-01-07 18:19:56 (18a217af): Starting playlist scan 2013-01-07 18:19:56 (18a217af): Updating playlists 2013-01-07 18:19:56 (18a217af): Error scanning MP3 files: No such file or directory 2013-01-07 18:19:56 (18a217af): Scanned 0 songs in 0 seconds 2013-01-07 18:19:56 (18a217af): Starting web server from /usr/pbi/firefly-amd64/share/mt-daapd/admin-root on port 3689 2013-01-07 18:19:56 (18a217af): Registering rendezvous names 2013-01-07 18:19:56 (18a217af): Serving 0 songs. Startup complete in 0 seconds 2013-01-08 09:04:41 (18a217af): Got shutdown signal. 2013-01-08 09:04:41 (18a217af): Stopping gracefully 2013-01-08 09:04:41 (18a217af): Stopping rendezvous daemon 2013-01-08 09:04:41 (18a217af): Closing database 2013-01-08 09:04:41 (18a217af): Done! 2013-01-08 09:04:46 (18a217af): Firefly Version svn-1696: Starting with debuglevel 2 2013-01-08 09:04:46 (18a217af): Error opening plugin dir /usr/lib/firefly/plugins. Ignoring 2013-01-08 09:04:46 (18a217af): Error opening plugin dir /usr/lib/mt-daapd/plugins. Ignoring 2013-01-08 09:04:46 (18a217af): Error opening plugin dir /lib/mt-daapd/plugins. Ignoring 2013-01-08 09:04:46 (18a217af): Error opening plugin dir /lib/mt-daapd/plugins. Ignoring 2013-01-08 09:04:46 (18a217af): Error loading plugin /usr/local/lib/mt-daapd/plugins/ssc-script.so: plugin declined to load 2013-01-08 09:04:46 (18a217af): Plugin loaded: rsp/svn-1696 2013-01-08 09:04:46 (18a217af): Plugin loaded: daap/svn-1696 2013-01-08 09:04:46 (18a217af): Starting rendezvous daemon 2013-01-08 09:04:46 (18a217af): Starting signal handler 2013-01-08 09:04:46 (18a217af): Initializing database 2013-01-08 09:04:46 (18a217af): Full reload... 2013-01-08 09:04:47 (18a217af): Starting mp3 scan 2013-01-08 09:26:30 (18a217af): Firefly Version svn-1696: Starting with debuglevel 2 2013-01-08 09:26:30 (18a217af): Error opening plugin dir /usr/lib/firefly/plugins. Ignoring 2013-01-08 09:26:30 (18a217af): Error opening plugin dir /usr/lib/mt-daapd/plugins. Ignoring 2013-01-08 09:26:30 (18a217af): Error opening plugin dir /lib/mt-daapd/plugins. Ignoring 2013-01-08 09:26:30 (18a217af): Error opening plugin dir /lib/mt-daapd/plugins. Ignoring 2013-01-08 09:26:30 (18a217af): Error loading plugin /usr/local/lib/mt-daapd/plugins/ssc-script.so: plugin declined to load 2013-01-08 09:26:30 (18a217af): Plugin loaded: rsp/svn-1696 2013-01-08 09:26:30 (18a217af): Plugin loaded: daap/svn-1696 2013-01-08 09:26:30 (18a217af): Starting rendezvous daemon 2013-01-08 09:26:30 (18a217af): Starting signal handler 2013-01-08 09:26:30 (18a217af): Initializing database 2013-01-08 09:26:30 (18a217af): Full reload... 2013-01-08 09:26:30 (18a217af): Starting mp3 scan 2013-01-08 13:49:19 (18a217af): Rendezvous socket closed (daap server crashed?) Aborting. 2013-01-08 13:49:19: Aborting 2013-01-08 14:40:46 (18a217af): Firefly Version svn-1696: Starting with debuglevel 2 2013-01-08 14:40:46 (18a217af): Error opening plugin dir /usr/lib/firefly/plugins. Ignoring 2013-01-08 14:40:46 (18a217af): Error opening plugin dir /usr/lib/mt-daapd/plugins. Ignoring 2013-01-08 14:40:46 (18a217af): Error opening plugin dir /lib/mt-daapd/plugins. Ignoring 2013-01-08 14:40:46 (18a217af): Error opening plugin dir /lib/mt-daapd/plugins. Ignoring 2013-01-08 14:40:47 (18a217af): Error loading plugin /usr/local/lib/mt-daapd/plugins/ssc-script.so: plugin declined to load 2013-01-08 14:40:47 (18a217af): Plugin loaded: rsp/svn-1696 2013-01-08 14:40:47 (18a217af): Plugin loaded: daap/svn-1696 2013-01-08 14:40:47 (18a217af): Starting rendezvous daemon 2013-01-08 14:40:47 (18a217af): Starting signal handler 2013-01-08 14:40:47 (18a217af): Initializing database 2013-01-08 14:40:47 (18a217af): Full reload... 2013-01-08 14:40:48 (18a217af): Starting mp3 scan 2013-01-08 19:01:38 (18a217af): Rendezvous socket closed (daap server crashed?) Aborting. 2013-01-08 19:01:38: Aborting
