Mikrz
- Aug 2, 2017
So I know this isn't fully how FreeNAS is meant to be set up initially but this is my first time with Freenas. luckily, my data isn't so important that I can't risk losing some.
Freenas version: FreeNAS-11-MASTER-201708240435
CPU: Intel core i3-6100
RAM: 8gb ddr4
I'm running Nightly as I was having issues with a drive import previously and running nightly allowed me to get the update. Is it possible to switch to a non-nightly train? I understand you cannot "downgrade" however I'm not against installing a stable train if there's a method of transferring configuration.
To get started, I had a 4TB red in the nas, and a 4TB to be added to it. I did my research, I understand that there will be no protection against either drive failing with this method. I went through the steps to extend the pool with the empty 4TB and selected "stripe" as the option. The progress bar sat around for a while, then the window closed and all seemed ok, except the console log at the bottom showed two entries of "Operation Not Permitted" on the new drive. I check my dataset list and it's showing it as only having 4~ terabytes of storage. Far less than the 7 something I expected with a stripe. I attempted to research what the issue could be, and found people saying that wiping the drive (the new drive was previously NTFS before I wiped it via Windows) before import can fix the issue, however it seems despite the issues importing FreeNAS just went ahead and striped what it could anyways. So I try the wipe option in freenas's volume manager, and it tells me to unmount my only "volume" (the striped one I suppose). Well, it's too late now to really go back, so I decided to just give it a shot. perhaps FreeNAS got stuck somewhere and detaching and re-importing my volumes will fix it.
I click detach volume on the root entry in the Storage tab, and make sure nothing will be deleted by unchecking both checkboxes shown to me. Then I let it run. About a minute later, I get a CallTimeout error, as seen here:
I'm currently staring at this window, and I have no idea if my data is still safe or not.
RAM: 8gb ddr4
Environment:
Software Version: FreeNAS-11-MASTER-201708240435 (3e42018)
Request Method: POST
Request URL: http://freenas.local/storage/detach/1/
Traceback:
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner
42. response = get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response
249. response = self._get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response
178. response = middleware_method(request, callback, callback_args, callback_kwargs)
File "./freenasUI/freeadmin/middleware.py" in process_view
162. return login_required(view_func)(request, *view_args, **view_kwargs)
File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view
23. return view_func(request, *args, **kwargs)
File "./freenasUI/storage/views.py" in volume_detach
747. cascade=form.cleaned_data.get('cascade', True))
File "./freenasUI/storage/models.py" in delete
367. systemdataset=systemdataset,
File "./freenasUI/storage/models.py" in _delete
331. n.stop(svc)
File "./freenasUI/middleware/notifier.py" in stop
225. return c.call('service.stop', what, {'onetime': onetime}, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/client/client.py" in call
352. raise CallTimeout("Call timeout")
Exception Type: CallTimeout at /storage/detach/1/
Exception Value: Call timeout
