You'd need to create the pool on an older version of FreeNAS that doesn't have the feature flags. Once updated, the pool will only work if all feature flags are supported.
Note that relying on this kind of setup long-term has been known to be problematic. Use it for temporary pools only.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
