I just noticed that my CPU has been hovering at about 25%, which equates to one of the cores being consumed.  I don't know what might be causing it... but I have a hunch.  I am currently using VMWare to clone a VM from an iSCSI zvol to a NFS dataset/share (all on the same underlying zfs volume).  Perhaps there is something special about the VMWare clone operation that causes excessive NIC interrupts, or introduces a high queue?
If I SSH to the server and run `top -SPH` I see:
Its just a wild guess, but it looks like my em0 interface has a large queue, which in turn is causing trouble. This system is not under heavy io load.
The em0 interface is used to access an NFS share as well as iscsi (there are two other interfaces used by the iscsi multipath)
I'm running FreeNAS-9.10-STABLE-201606270534 (dd17351)
last pid: 57338;  load averages:  1.19,  1.24,  1.19        up 23+06:51:36  16:12:44
788 processes: 6 running, 764 sleeping, 18 waiting
CPU 0:  0.0% user,  0.0% nice,  1.9% system,  0.0% interrupt, 98.1% idle
CPU 1:  0.0% user,  0.0% nice, 12.1% system,  0.0% interrupt, 87.9% idle
CPU 2:  0.0% user,  0.0% nice,  1.9% system,  0.0% interrupt, 98.1% idle
CPU 3:  0.0% user,  0.0% nice,  100% system,  0.0% interrupt,  0.0% idle
Mem: 175M Active, 9846M Inact, 13G Wired, 51M Cache, 299M Free
ARC: 10G Total, 1472M MFU, 8124M MRU, 690K Anon, 747M Header, 388M Other
Swap: 20G Total, 16K Used, 20G Free
  PID USERNAME   PRI NICE   SIZE    RES STATE   C   TIME    WCPU COMMAND
    0 root       -92    -     0K  9728K CPU3    3  21.5H 100.00% kernel{em0 que}
   11 root       155 ki31     0K    64K CPU0    0 553.0H  98.19% idle{idle: cpu0}
   11 root       155 ki31     0K    64K CPU1    1 552.6H  95.26% idle{idle: cpu1}
   11 root       155 ki31     0K    64K RUN     2 552.3H  93.90% idle{idle: cpu2}
    7 root       -16    -     0K    32K psleep  1  95:01   7.76% pagedaemon{pagedaemon}
57100 root        20    0 26064K  4468K CPU2    2   0:03   0.59% top
   11 root       155 ki31     0K    64K RUN     3 533.0H   0.00% idle{idle: cpu3}
....SNIP...
[root@zfs] ~# gstat -bI5s -f 'da[0-7]p2|ada[0-1]p2|ada0p1'
dT: 5.016s  w: 5.000s  filter: da[0-7]p2|ada[0-1]p2|ada0p1
L(q)  ops/s    r/s   kBps   ms/r    w/s   kBps   ms/w   %busy Name
    0      6      0      0    0.0      6     57    0.2    0.3  da0p2
    0      6      0      0    0.0      6     57    0.6    0.7  da1p2
    0      6      0      0    0.0      6     57    0.6    0.6  da2p2
    0      6      0      0    0.0      6     57    0.6    0.7  da3p2
    0      7      0      0    0.0      7    160    1.0    2.1  da4p2
    0      8      0      0    0.0      7    160    0.8    2.2  da5p2
    0      2      0      0    0.0      2     54    0.2    0.8  da6p2
    0      2      0      0    0.0      2     54    0.2    0.9  da7p2
    0     16      0      0    0.0      8    160    0.1    1.8  ada0p1
    0     15      0      4    0.2     15    757    0.1    0.2  ada0p2
    0      3      0      0    0.0      2    124    0.3    0.9  ada1p2
    0      3      0      0    0.0      2    124    0.3    0.8  ada2p2
[root@zfs] ~# ifconfig em0
em0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 9000
        options=4019b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,TSO4,VLAN_HWTSO>
        ether 00:15:17:6a:6c:3f
        inet 172.16.1.1 netmask 0xffffff00 broadcast 172.16.1.255
        media: Ethernet autoselect (1000baseT <full-duplex>)
        status: active
