Excellent performance on CIFS, much lower on iSCSI and miserable on NFS
Sbi
My current setup is based on:
Dell T410
LSI SAS 9211-8i
32 GB RAM
2x Xeon E5620 2.4GHz
RAIDZ2 (4x SAS seagate constellation es.3 drives) with lz4 commpression enabled
4x 1 Gbe NICs (Intel + Broadcom)
1x 10 Gbe NIC (Intel X540-T2)
10 NETGEAR XS708T 10GbE switch
Cat6A Cables
3x ESXi hosts with Intel X540-T2 for iSCSI/NFS purpose
FreeNAS-9.10.1
With iSCSI share i got approximately 600 Mbits/sec and NFS showed even less - 300 Mbits/sec max.
In the same time i've managed to push CIFS with 1 Gbit/sec which is the limit of my client workstation (not ESXi hosts).
Iperf test between FreeNAS and ESXi host showed 8 Gbit/sec.
FreeNAS is set with default settings.
Interesting thing happened when I decided to test same setup on NAS4free iSCSI share. I've got 2.2-2.5 Gbit/sec stable result. NFS share gave me the same as on FreeNAS.
Btw result was the same with jumbo frames and without them as well as with 1 Gbe NICs.
Here is some dd testing:
dd if=/dev/zero of=/mnt/primvol/testfile bs=1024k count=25k
^C21606+0 records in
21605+0 records out
22654484480 bytes transferred in 68.953910 secs (328545320 bytes/sec)
dd if=/dev/zero of=/mnt/primvol/testfile bs=4M count=10000
^C6153+0 records in
6152+0 records out
25803358208 bytes transferred in 86.836757 secs (297147880 bytes/sec)
300 MB/s is not the same i can get from NFS share:( It's up to 10 times lower than the system can give.
From this perspective I'd like to know "What I'm doing wrong???".
Mirfster
You want to do the DD Testing with Compression Off
Performance suggestions:
  • Use Mirror vDevs
  • Get a proper SLOG
  • Toss in more RAM
  • For iSCSI you want to use zVol instead of DataSet
Some test results I posted for the OP are in this thread
  • Like
Reactions: Sbi
Performance is always going to suck when using block devices for sharing. Especially with a single vdev.
