I tried running freenas on ESXI host and Raw Device Mappings, so my hdd's is connected directly to the VM machine and it runs amazing. Same speed as if its a physical pc..
Before that...
I tried freenas but it was slow.
Then i installed openindiana and napp-it.
Same happens my raidz2 slow too. But then I noticed in the disk load interface in "napp-it" that 1 of my disks was loaded 100% and the others is idle(0%).
I replaced the disk that reported 100% load and speed goes from 10 MB/s to 110 MB/s netcard limit.
So something is wrong with that disk.
I want to know if there is any place in FREENAS I can see load on every single disk ? Like I can in Napp-it, cause that interface in napp-it lead me to the fail.
Well but I also want to tell people that ESXI with RDM (Raw Device Mappings) is working perfect. So now I can setup a system on 1 server instead of 2 server, and RDM does not reqiuere VT-d or anything, i also tried with enabling VT-d and give the freenas server direct access to my hdd's but that didnt work for me with onboard sata controller. Cause all sata ports was in family with intel controller.
Before that...
