Errors in TrueNAS 12.0-U2, and disks not showing info
WB3FFV
I have a Dell R720xd running TrueNAS 12.0-U2, and have a dozen SAS drives installed, and decided to double my space, so added on an MD1200 expansion shelf with another 12 drives. After doing this, everything was running fine, and then I rebooted, and after the reboot it now no longer shows the Discs as allocated, but they are part of Pool-2 on the server, and everything is usable. So in Disks, all the N/A's are actually all part of Pool-2.
Looking at the console I see lots of errors like this:
Feb 23 12:27:02 tnas720 metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 93891, spa Pool-2, vdev_id 1, ms_id 371,
 smp_length 0, unflushed_allocs 0, unflushed_frees 0, freed 0, defer 0 + 0, unloaded time 93394 ms, loading_time 0 ms, ms
_max_size 17179869184, max size error
Feb 23 12:27:02 tnas720 metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 93891, spa Pool-2, vdev_id 1, ms_id 373,
Feb 23 12:27:02 tnas720 metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 93891, spa Pool-2, vdev_id 0, ms_id 377,
Feb 23 12:27:02 tnas720 metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 93891, spa Pool-2, vdev_id 0, ms_id 370,
Feb 23 12:27:02 tnas720 metaslab.c:2422:metaslab_load_impl(): metaslab_load: txg 93891, spa Pool-2, vdev_id 0, ms_id 371,
I will include a couple screen caps from the GUI, but this looks like things are OK, just the disks info is not populating right, but it would sure bite to have a disk allocated that is already in use.
Any ideas??
