error with boot volume after update
chen2059
Getting the following critical alert after latest update of 11.2 u3.
CRITICAL:The boot volume state is ONLINE: One or more devices has experienced an error resulting in data corruption. Applications may be affected.
[root@freenas ~]# zpool status -v | more
  pool: DATA
 state: ONLINE
  scan: resilvered 404M in 0 days 00:00:05 with 0 errors on Sun Mar 31 15:03:452019
        DATA                                            ONLINE       0     0 0
          raidz2-0                                      ONLINE       0     0 0
            gptid/cf5212d8-0da3-11e9-951f-7085c27b6fb4  ONLINE       0     0 0
            gptid/d053749a-0da3-11e9-951f-7085c27b6fb4  ONLINE       0     0 0
            gptid/d1990a82-0da3-11e9-951f-7085c27b6fb4  ONLINE       0     0 0
            gptid/d2e31612-0da3-11e9-951f-7085c27b6fb4  ONLINE       0     0 0
        logs
          gptid/5af9968e-32b8-11e9-80af-7085c27b6fb4    ONLINE       0     0 0
errors: No known data errors
  pool: freenas-boot
 state: ONLINE
action: Restore the file in question if possible.  Otherwise restore the
        entire pool from backup.
   see: http://illumos.org/msg/ZFS-8000-8A
  scan: none requested
        freenas-boot  ONLINE       0     0     1
          ada2p2    ONLINE       0     0     2
        //usr/local/lib/python3.6/site-packages/aiohttp/__pycache__/tcp_helpers.cpython-36.opt-1.pyc
I’m a newbie.Should I do this now?
D
dlavigne
Guest
Your boot device has failed. Reinstall the same version to a new boot media and restore your previously saved config.
chen2059
Thank you for your reply.I have used the u disk to reinstall the system on the original ssd, but still show this error.
D
dlavigne
Guest
That won't help if the original SSD has failed, which is probably what happened. You will need to install to a new boot device.
chen2059
But original ssd can still start normally, just jump out of alerts.ssd itself is not bad, just the system has a problem
NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 1 ada2p2 ONLINE 0 0 2
This part means that you have some corrupt sectors on the boot device. This is usually an indication that the drive will soon fail completely. You should not ignore this warning if you care about your system and your access to the data on it (the data should remain safe in any case).
The replacement of a boot drive (particularly if it's just a USB stick) is easy and relatively risk-free as long as you're doing it as part of a plan.
I recommend replacing it as soon as you can.
chen2059
Thank you for your reminder, I will replace it as soon as possible.
