SOLVED Error when creating Ubuntu VM
stephenreda
I an running:
Version:
FreeNAS-11.3-U3.1
Physical Memory:
16213 MiB
Model:
Intel(R) Core(TM) i5-4670 CPU @ 3.40GHz
I followed this procedure:
  1. Downloaded latest Ubuntu Server (also tried Desktop) ISO on the local filesystem
  2. Used default settings to add a Linux VM
Summary:
VM Summary
  • Guest Operating System : Linux
  • Number of CPUs : 1
  • Memory : 512 MiB
  • Disk Size : 100 GiB
  • Installation Media : /mnt/Main/Open/ubuntu-20.04-live-server-amd64.iso
Confirm these settings.
I always get the following failure when starting the VM and opening VNC:
I saw a similiar report on reddit from not so long ago:
https://www.reddit.com/r/freenas/comments/gljoes/initramfs_unpacking_failed_write_error/
In the threat they suggested that 512 Mib is not enough so I changed it to 1024M.
I now see the first install window from Ubuntu
but when selecting the default, I get to see the same error message.
Samuel Tai
Change your disk type to VirtIO. Also, you don't have enough RAM allocated to hold the initramfs. You need at least 2048 MiB.
stephenreda
Thanks Samuel. For others searching on this: updating the Memory size via edit on an existing VM didn't change it. I had to recreate the VM with enough Memory.
Samuel Tai
You can't edit the memory on a running VM. You can if the VM is not running.
