Error connecting to OwnCloud
Slacker ITADM
Here is what I got at my first login attempt using the Own Cloud plugin in FreeNas 9.10
Not quite sure what it is referring to or what to change(obvious NOB)
pirateghost
Unintelligible Geek
It literally tells you that the directory within your owncloud jail is readable by others. Login to the CLI in the jail and fix the permissions as it instructs you to.
