I'm trying to connect FreeNAs to AD but I get this error:
"Unable to find domain controllers for nvf.local."
In /var/log/debug.log I can see:
May 26 20:02:33 freenas manage.py: [common.freenasldap:1157] FreeNAS_ActiveDirectory_Base.get_SRV_records: looking up SRV records for _ldap._tcp.dc._msdcs.nvf.local
May 26 20:03:03 freenas manage.py: [common.freenasldap:1169] FreeNAS_ActiveDirectory_Base.get_SRV_records: no SRV records for _ldap._tcp.dc._msdcs.nvf.local found, fail!
May 26 20:03:03 freenas manage.py: [common.freenasldap:12] Traceback (most recent call last):
May 26 20:03:03 freenas manage.py: [common.freenasldap:12] File "/usr/local/www/freenasUI/../freenasUI/common/freenasldap.py", line 1159, in get_SRV_records
May 26 20:03:03 freenas manage.py: [common.freenasldap:12] answers = resolver.query(host, 'SRV')
May 26 20:03:03 freenas manage.py: [common.freenasldap:12] File "/usr/local/lib/python2.7/site-packages/dns/resolver.py", line 981, in query
May 26 20:03:03 freenas manage.py: [common.freenasldap:12] raise_on_no_answer, source_port)
May 26 20:03:03 freenas manage.py: [common.freenasldap:12] File "/usr/local/lib/python2.7/site-packages/dns/resolver.py", line 901, in query
May 26 20:03:03 freenas manage.py: [common.freenasldap:12] timeout = self._compute_timeout(start)
May 26 20:03:03 freenas manage.py: [common.freenasldap:12] File "/usr/local/lib/python2.7/site-packages/dns/resolver.py", line 739, in _compute_timeout
May 26 20:03:03 freenas manage.py: [common.freenasldap:12] raise Timeout
May 26 20:03:03 freenas manage.py: [common.freenasldap:12] Timeout
I can ping the server as you can see, and the resolution is fine:
[root@freenas /var/log]# ping srvlotus2.nvf.local
PING srvlotus2.nvf.local (10.0.10.11): 56 data bytes
64 bytes from 10.0.10.11: icmp_seq=0 ttl=128 time=0.109 ms
[root@freenas /var/log]# ping nvf.local
PING nvf.local (10.0.10.11): 56 data bytes
64 bytes from 10.0.10.11: icmp_seq=0 ttl=128 time=0.080
Any ideas? Any other log whre I can find more information about which can be the issue here?
Thanks a lot!
Thanks a lot!
