Errno 28 after upgrade freenas 9.10
abadanvolek
I upgraded my freenas from 9.21 to 9.10 and when the zpool was imported it reports error:
[Errno 28] No space left on device: '/var/db/system/cores'
[root@freenas] ~# df -h
Filesystem Size Used Avail Capacity Mounted on
freenas-boot/ROOT/default 7.7G 594M 7.1G 8% /
devfs 1.0K 1.0K 0B 100% /dev
tmpfs 32M 8.1M 24M 25% /etc
tmpfs 4.0M 8.0K 4.0M 0% /mnt
tmpfs 2.7G 82M 2.6G 3% /var
freenas-boot/grub 7.1G 6.3M 7.1G 0% /boot/grub
fdescfs 1.0K 1.0K 0B 100% /dev/fd
linprocfs 4.0K 4.0K 0B 100% /compat/linux/proc
freenas_vol1 128K 128K 0B 100% /mnt/freenas_vol1
freenas_vol1/.system 144K 144K 0B 100% /var/db/system
freenas_vol1/.system/cores 584K 584K 0B 100% /var/db/system/cores
freenas_vol1/.system/samba4 196K 196K 0B 100% /var/db/system/samba4
[root@freenas] ~# zfs list
NAME USED AVAIL REFER MOUNTPOINT
freenas-boot 604M 7.10G 31K none
freenas-boot/ROOT 597M 7.10G 25K none
freenas-boot/ROOT/Initial-Install 1K 7.10G 594M legacy
freenas-boot/ROOT/default 597M 7.10G 594M legacy
freenas-boot/grub 6.33M 7.10G 6.33M legacy
freenas_vol1 3.56T 0 128K /mnt/freenas_vol1
freenas_vol1/.system 1.72M 0 144K legacy
freenas_vol1/.system/cores 584K 0 584K legacy
freenas_vol1/.system/rrd-be4fe75a1a20491bb9c8a8ad950f3be0 144K 0 144K legacy
freenas_vol1/.system/samba4 196K 0 196K legacy
freenas_vol1/.system/syslog-be4fe75a1a20491bb9c8a8ad950f3be0 692K 0 692K legacy
freenas_vol1/NAS_VOL1 3.56T 3.15T 420G -
D
dlavigne
Guest
Please paste the output of zpool status using Insert -> Code.
D
dlavigne
Guest
If zpool status is happy, your volume is fine. Looks like Volume Manager is confused by migrating from such an earlier version. Changing the location of the system dataset in System -> System Dataset would might unconfuse it.
