Hi All,
I recently switched from TrueNAS Core to TrueNAS Scale so that I could get GPU acceleration working in Plex (via Docker).
I'm really loving Scale as more of my background is in Linux, although I had the issue I'm about to link to on both platforms!
I made a post last night to stackexchange detailing my situation - but I thought it might be better placed here.
I did search the forums, and the only posts I could find which came close were:
www.truenas.com
www.truenas.com
I may well go ahead with garm's suggestion and:
> rsync and then snapshot the encrypted dataset once rsync is finished
If I can't make sense of what I want to do.
Thanks in advance to anyone who responds!
Encrypted dataset replication: setting --raw flag?
I am just starting out with FreeNAS/TrueNAS in preparation for a set of builds I will doing this month. I'm very excited about the new zfs encryption and the marketed ability to send an encrypted dataset to an offsite TrueNAS without also sending the encryption keys. Unfortunately, I ran into an...
ZFS replication to ZoL encrypted dataset?
Intrigued by a suggestion from @garm, I'm trying to set up an Odroid HC2 as a replication target for FreeNAS. The HC2 is a single-board computer with a SATA interface, mounted to a heatsink that'll easily hold a 3.5" HDD. It runs Linux (among other things, though not FreeBSD) and should make...
