I'm using truenas scale 23.10.0.1 installed on bare metal.
I've created a bridge and attached it to the physical nic, IP configuration for the instance is applied to the bridge. I have an ubuntu VM running that hosts my docker containers.
I have enabled jumbo frames on the host nic, br0, and VM interfaces. However, I've found that jumbos will only work between the VM and Truenas instance if I also modify the MTU on the vnet1 interface using the "ip" command. Is there a proper way to configure the MTU for this interface within the gui? If not, what is the proper way for me to make this change persistent across reboots?
