Hello everyone, i have been (silently) using FreeNAS for some years now and beside the usual major update challenges i managed to safely keep my data. Until now. As always i was coming first here to find help (pretty much everytime) but know i think i am stuck and just want to be sure, there is nothing i missed/didn't see here.
TL;DR Update from 11.1-U6 to 11.7-U2 -> empty datasets after encrypted volume import while still showing a lot of used space
Background:
- Update from 11.1-U6 to 11.2-U2
- Had issues with USB boot stick as decribed here and here
- Bought another stick and did fresh install with imported config DB and pools
- Had a lot of struggle with SMB configurations which are broken, see here
- Importing my encrypted RAIDZ1 pool always worked without any reported issues, until i looked inside the datasets and found them empty
Of course i utilized several zfs/zpool commands
So yeah pool and datasets look fine. I found this thread about directories shadowing dataset mounts but unmounting the directories did not reveal anything (but unmounted/removed the dataset). Ok i checked via
One can see only a few zfs action and mainly imports of the pool due to power on/off. After the update to 11.2 i played around with new jails via iocage. The old owncloud jail could be started via legacy UI and worked before the first restart of 11.2-U2 (see boot issue).
I see a growing number of issues and bugs, e.g. here. So in short, if you go to mount/directory its empty even though data set shows a lot of used space. I checked the details of the pool
You can see usedbydataset is pretty small and all the data remains with snapshots as seen in usedbysnapshots. The snapshots are pretty old (yes, my fault esp. given an FreeNAS OS upgrade). I reverted back to 11.1-U7 but same situation...
SO, before trying to re-create from snapshots, is there anything i missed? Something i can try?
And for helping out with tracing down the bug, can i provide anything? Obviously my old logs are gone
Background:
zfs list NAME USED AVAIL REFER MOUNTPOINT ... pool 1.35T 3.90T 128K /mnt/pool pool/Share 269G 3.90T 117K /mnt/pool/Share pool/backup 270G 3.90T 117K /mnt/pool/backup pool/data ...
zpool status pool
pool: pool
state: ONLINE
scan: scrub repaired 0 in 0 days 10:03:36 with 0 errors on Sun Jan 13 10:03:39 2019
NAME STATE READ WRITE CKSUM
pool ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
gptid/2401a9d8-76ce-11e8-898c-c8cbb8c53651.eli ONLINE 0 0 0
gptid/25203d9e-76ce-11e8-898c-c8cbb8c53651.eli ONLINE 0 0 0
gptid/26f86cb7-76ce-11e8-898c-c8cbb8c53651.eli ONLINE 0 0 0
errors: No known data errors
sudo zpool history pool if i made any errorsCode:
2018-06-23.12:14:10 zpool create -o cachefile=/data/zfs/zpool.cache -o failmode=continue -o autoexpand=on -O compression=lz4 -O aclmode=passthrough -O aclinherit=passthrough -f -m /pool -o altroot=/mnt pool raidz /dev/gptid/2401a9d8-76ce-11e8-898c-c8cbb8c53651.eli /dev/gptid/25203d9e-76ce-11e8-898c-c8cbb8c53651.eli /dev/gptid/26f86cb7-76ce-11e8-898c-c8cbb8c53651.eli 2018-06-23.12:14:15 zfs inherit mountpoint pool 2018-06-23.12:14:15 zpool set cachefile=/data/zfs/zpool.cache pool 2018-06-23.13:42:34 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 1527957841801345122 2018-06-23.13:42:34 zpool set cachefile=/data/zfs/zpool.cache pool 2018-06-23.14:39:52 zfs destroy pool@migrate 2018-06-24.07:39:37 zfs receive -Fv pool 2018-06-24.12:12:17 zpool import -f -R /mnt 1527957841801345122 2018-06-24.12:12:20 zfs inherit -r mountpoint pool 2018-06-24.12:12:20 zpool set cachefile=/data/zfs/zpool.cache pool 2018-06-24.12:12:21 zfs set aclmode=passthrough pool 2018-06-24.12:12:26 zfs set aclinherit=passthrough pool 2018-06-24.12:25:52 zpool scrub pool 2018-06-25.16:46:08 zpool import -f -R /mnt 1527957841801345122 2018-06-25.16:46:12 zfs inherit -r mountpoint pool 2018-06-25.16:46:12 zpool set cachefile=/data/zfs/zpool.cache pool 2018-06-25.16:46:12 zfs set aclmode=passthrough pool 2018-06-25.16:46:17 zfs set aclinherit=passthrough pool 2018-06-25.16:48:52 zpool export -f pool 2018-06-25.16:49:37 zpool import -f -R /mnt 1527957841801345122 2018-06-25.16:49:40 zfs inherit -r mountpoint pool 2018-06-25.16:49:40 zpool set cachefile=/data/zfs/zpool.cache pool 2018-06-25.16:49:40 zfs set aclmode=passthrough pool 2018-06-25.16:49:46 zfs set aclinherit=passthrough pool 2018-07-07.19:58:35 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 1527957841801345122 2018-07-07.19:58:35 zpool set cachefile=/data/zfs/zpool.cache pool 2018-08-05.00:00:11 zpool scrub pool 2018-08-13.15:16:00 zfs create -o quota=none -o refquota=300G -o reservation=none -o refreservation=none -o org.freenas:description=Apple Time Machine -o sync=disabled -o compression=off -o casesensitivity=sensitive pool/time-machine 2018-08-13.15:16:05 zfs set aclmode=passthrough pool/time-machine 2018-09-16.00:00:10 zpool scrub pool 2018-09-23.18:33:58 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 1527957841801345122 2018-09-23.18:33:58 zpool set cachefile=/data/zfs/zpool.cache pool 2018-10-28.00:00:12 zpool scrub pool 2018-11-23.11:53:49 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 1527957841801345122 2018-11-23.11:53:49 zpool set cachefile=/data/zfs/zpool.cache pool 2018-12-01.14:54:34 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 1527957841801345122 2018-12-01.14:54:34 zpool set cachefile=/data/zfs/zpool.cache pool 2018-12-02.00:00:11 zpool scrub pool 2019-01-10.19:24:13 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 1527957841801345122 2019-01-10.19:24:13 zpool set cachefile=/data/zfs/zpool.cache pool 2019-01-11.19:32:01 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 1527957841801345122 2019-01-11.19:32:01 zpool set cachefile=/data/zfs/zpool.cache pool 2019-01-13.00:00:12 zpool scrub pool 2019-02-14.10:45:18 zfs create -o quota=none -o refquota=none -o reservation=none -o refreservation=3T -o org.freenas:description=plots -o compression=off -o casesensitivity=sensitive pool/plots0 2019-02-14.10:45:23 zfs set aclmode=restricted pool/plots0 2019-02-14.10:46:06 zfs set quota=none pool/plots0 2019-02-14.10:46:06 zfs set refquota=none pool/plots0 2019-02-14.10:46:06 zfs set reservation=none pool/plots0 2019-02-14.10:46:06 zfs set refreservation=3T pool/plots0 2019-02-14.10:46:07 zfs set org.freenas:description=plots pool/plots0 2019-02-14.10:46:07 zfs inherit sync pool/plots0 2019-02-14.10:46:07 zfs set compression=off pool/plots0 2019-02-14.10:46:07 zfs inherit atime pool/plots0 2019-02-14.10:46:07 zfs inherit dedup pool/plots0 2019-02-14.10:46:07 zfs inherit recordsize pool/plots0 2019-02-14.10:46:08 zfs inherit readonly pool/plots0 2019-02-14.10:46:13 zfs set aclmode=restricted pool/plots0 2019-02-17.13:47:15 zpool import -f -R /mnt 1527957841801345122 2019-02-17.13:47:20 zfs inherit -r mountpoint pool 2019-02-17.13:47:20 zpool set cachefile=/data/zfs/zpool.cache pool 2019-02-17.13:47:20 zfs set aclmode=passthrough pool 2019-02-17.13:47:25 zfs set aclinherit=passthrough pool 2019-02-17.14:31:02 <iocage> zfs set org.freebsd.ioc:active=yes pool 2019-02-17.14:34:17 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 1527957841801345122 2019-02-17.14:34:17 zpool set cachefile=/data/zfs/zpool.cache pool 2019-02-17.14:38:00 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 1527957841801345122 2019-02-17.14:38:00 zpool set cachefile=/data/zfs/zpool.cache pool 2019-02-18.10:33:43 zfs destroy -fr pool/system/jails/murmur 2019-02-18.21:46:52 zpool import -c /data/zfs/zpool.cache.saved -o cachefile=none -R /mnt -f 1527957841801345122 2019-02-18.21:46:52 zpool set cachefile=/data/zfs/zpool.cache pool 2019-02-18.21:59:33 <iocage> zfs mount pool/iocage 2019-02-18.21:59:34 <iocage> zfs mount pool/iocage/download 2019-02-18.21:59:35 <iocage> zfs mount pool/iocage/images 2019-02-18.21:59:35 <iocage> zfs mount pool/iocage/jails 2019-02-18.21:59:36 <iocage> zfs mount pool/iocage/log 2019-02-18.21:59:36 <iocage> zfs mount pool/iocage/releases 2019-02-18.21:59:38 <iocage> zfs mount pool/iocage/templates 2019-02-18.22:13:07 zfs set aclmode=passthrough pool/plots0 2019-02-18.22:22:38 zfs set aclmode=passthrough pool/plots0 2019-02-18.22:31:59 <iocage> zfs mount pool/iocage/download/11.2-RELEASE 2019-02-18.22:32:20 <iocage> zfs mount pool/iocage/releases/11.2-RELEASE/root 2019-02-18.22:33:59 zfs snapshot pool/iocage/releases/11.2-RELEASE/root@plots0 2019-02-18.22:34:01 zfs clone -p pool/iocage/releases/11.2-RELEASE/root@ plots0 pool/iocage/jails/plots0/root 2019-02-19.01:54:59 <iocage> zfs destroy plots0 2019-02-19.01:55:01 <iocage> zfs destroy pool/iocage/jails/plots0/root 2019-02-19.01:55:05 <iocage> zfs destroy pool/iocage/jails/plots0 2019-02-21.12:38:59 zpool import -f -R /mnt 1527957841801345122 2019-02-21.12:38:59 zpool set cachefile=/data/zfs/zpool.cache pool 2019-02-21.12:42:18 zfs set refreservation=none pool/plots0 2019-02-21.12:42:18 zfs set copies=1 pool/plots0 2019-02-21.12:42:23 zfs set aclmode=passthrough pool/plots0 2019-02-21.13:10:04 zpool import -f -R /mnt 1527957841801345122 2019-02-21.13:10:04 zpool set cachefile=/data/zfs/zpool.cache pool 2019-02-21.13:29:33 zpool import -f -R /mnt 1527957841801345122 2019-02-21.13:29:33 zpool set cachefile=/data/zfs/zpool.cache pool 2019-02-21.17:02:44 zpool import -f -R /mnt 1527957841801345122 2019-02-21.17:02:52 zfs inherit -r mountpoint pool 2019-02-21.17:02:52 zpool set cachefile=/data/zfs/zpool.cache pool 2019-02-21.17:02:52 zfs set aclmode=passthrough pool 2019-02-21.17:02:55 zfs set aclinherit=passthrough pool 2019-02-21.17:02:56 zfs set mountpoint=legacy pool/.system 2019-02-21.17:14:46 zpool import -f -R /mnt 1527957841801345122 2019-02-21.17:14:53 zfs inherit -r mountpoint pool 2019-02-21.17:14:53 zpool set cachefile=/data/zfs/zpool.cache pool 2019-02-21.17:14:53 zfs set aclmode=passthrough pool 2019-02-21.17:14:58 zfs set aclinherit=passthrough pool 2019-02-21.17:37:02 zpool export -f pool 2019-02-21.17:37:45 zpool import -f -R /mnt 1527957841801345122 2019-02-21.17:37:52 zfs inherit -r mountpoint pool 2019-02-21.17:37:52 zpool set cachefile=/data/zfs/zpool.cache pool 2019-02-21.17:37:52 zfs set aclmode=passthrough pool 2019-02-21.17:37:57 zfs set aclinherit=passthrough pool 2019-02-21.17:45:22 zfs set mountpoint=/mnt/pool/data/ pool/data 2019-02-21.17:47:09 zfs set mountpoint=/pool/data/ pool/data 2019-02-21.18:00:43 zpool export pool 2019-02-21.18:11:10 zpool import -f -R /mnt 1527957841801345122 2019-02-21.18:11:16 zpool set cachefile=/data/zfs/zpool.cache pool 2019-02-21.18:11:16 zfs set aclmode=passthrough pool 2019-02-21.18:11:21 zfs set aclinherit=passthrough pool
zfs get all pool/data NAME PROPERTY VALUE SOURCE pool/data type filesystem - pool/data creation Sat Jun 23 21:42 2018 - pool/data used 441G - pool/data available 3.90T - pool/data referenced 117K - pool/data compressratio 1.03x - pool/data mounted yes - pool/data quota none default pool/data reservation none default pool/data recordsize 128K default pool/data mountpoint /mnt/pool/data default pool/data sharenfs off default pool/data checksum on default pool/data compression lz4 inherited from pool pool/data atime on default pool/data devices on default pool/data exec on default pool/data setuid on default pool/data readonly off default pool/data jailed off default pool/data snapdir hidden default pool/data aclmode passthrough inherited from pool pool/data aclinherit passthrough inherited from pool pool/data canmount on default pool/data xattr off temporary pool/data copies 1 default pool/data version 5 - pool/data utf8only off - pool/data normalization none - pool/data casesensitivity sensitive - pool/data vscan off default pool/data nbmand off default pool/data sharesmb off default pool/data refquota none default pool/data refreservation none default pool/data primarycache all default pool/data secondarycache all default pool/data usedbysnapshots 441G - pool/data usedbydataset 117K - pool/data usedbychildren 0 - pool/data usedbyrefreservation 0 - pool/data logbias latency default pool/data dedup off default pool/data mlslabel - pool/data sync standard default pool/data refcompressratio 1.00x - pool/data written 95.9K - pool/data logicalused 453G - pool/data logicalreferenced 36.5K - pool/data volmode default default pool/data filesystem_limit none default pool/data snapshot_limit none default pool/data filesystem_count none default pool/data snapshot_count none default pool/data redundant_metadata all default pool/data org.freenas:description received pool/data org.freebsd.ioc:active yes inherited from pool
