[EFAULT] pkg.cdn.trueos.org could not be reached via DNS, check your network
yomismo
version 11,2 beta 3
steps i try to install nextcloud
root@freenas:~ # nslookup pkg.cdn.trueos.org
Server:
Address:
Non-authoritative answer:
pkg.cdn.trueos.org	canonical name = pkg.pcbsd.scaleengine.net.
pkg.pcbsd.scaleengine.net	canonical name = pcbsd-pkg.secdn.net.
Address: 54.37.238.114
Address: 2a00:7b80:3012:2b::1:81
what is happening ?
D
dlavigne
Guest
Was this solved? If so, what was the question and what was the answer?
multi.flexi
I have exactly the same issue, nslookup is fine but when installing plugin, this error happens
multi.flexi
Has anyone done a bug report? Should I make one?
I guess you can. I also noticed that in old GUI I have no choice to install new plugins, just list of installed, but in new GUI I can see list of available plugins.
ajzimme
I believe this is related.
pyto
that package is not found because it does not exist on that server. The correct adres is
http://pkg.cdn.trueos.org/iocage/11.2-RELEASE/Latest/pkg.txz
ajzimme
johnsondal
Did you check your /etc/resolv.conf file? This file is copied into the Jail when plugins are created and determine the DNS servers to use. Updated mine and plugins work without issue.
ipinternet
I found a way to solve this plugin installation problem. Ignore getting IP from DHCP and it works. When installing plugin simply uncheck DHCP option. Then select your Ethernet interface. Enter an ip from your network subnet and choose desired subnet mask. Then click save and plugin should be start installing.
[Notes]: If problem exists then edit your resovle.conf file [ nano /etc/resolve.conf]. Delete everything [ there should be an entry search local; (also delete this). Delete everything and enter only nameserver 8.8.8.8.
jottos
I found a way to solve this plugin installation problem. Ignore getting IP form DHCP and it works. When installing plugin simply uncheck DHCP option. Then select your Ethernet interface. Enter an IP from your network subnet and choose desired subnet mask. Then click save and plugin should be start installing.
Hi, so this was really helpful because I had originally had set a static IP address the way you did, but I was getting the same error. I was able to ping the internet from my jail by jexec'd to my jail and pinging. You are correct to point out that editing the /etc/resolve.conf file because I have found that there is a bug saving the name servers in 11.x freenas requiring me to set the /etc/resolv.conf file every time I reboot.
Here is where my experience differs from yours. Reading your post is saw you toggled the DHCP -> Static IP. So I toggled my Static -> DHCP and it worked. There is clearly something jenky going on with the jail setup that toggling this setting, which likely restarts the jail network, is fixing I don't think either setting is bad, I think the network is not setting properly on jail creation.
thanks for you post, it helped a lot!
pt4117
I had this issue with my FreeNAS running on esxi. My issue was the vswitch wasn't configured correctly. I had to edit it and allow Promiscuous mode under Security.
