Edit crontab in jail
*/1 * * * * bash -I -c "/root/sync.sh >/tmp/stdout_2.txt 2>/tmp/stderr_2.txt"
that is what I have in crontab -e
Without the bash -c it won't run, and I get the same mirror error with -I or without.
I also note the OP is using bash too...
babaz83
Tried also changing everything to /bin/sh nothing works.
This is the log from Cron
Aug 22 14:28:00 rclone /usr/sbin/cron[35591]: (root) CMD (/usr/share/test.sh 2>&1 >/var/log/test.txt)
Aug 22 14:28:00 rclone /usr/sbin/cron[35592]: (root) CMD (root /bin/sh -x /usr/share/RcloneBzSync.sh >/var/log/cron.txt 2>&1)
Aug 22 14:29:00 rclone /usr/sbin/cron[35635]: (root) CMD (/usr/share/test.sh 2>&1 >/var/log/test.txt)
Aug 22 14:29:00 rclone /usr/sbin/cron[35636]: (root) CMD (root /bin/sh -x /usr/share/RcloneBzSync.sh >/var/log/cron.txt 2>&1)
Aug 22 14:30:00 rclone /usr/sbin/cron[35662]: (root) CMD (/usr/libexec/atrun)
Aug 22 14:30:00 rclone /usr/sbin/cron[35663]: (root) CMD (root /bin/sh -x /usr/share/RcloneBzSync.sh >/var/log/cron.txt 2>&1)
Aug 22 14:30:00 rclone /usr/sbin/cron[35664]: (root) CMD (/usr/share/test.sh 2>&1 >/var/log/test.txt)
Aug 22 14:31:00 rclone /usr/sbin/cron[35708]: (root) CMD (/usr/share/test.sh 2>&1 >/var/log/test.txt)
Aug 22 14:31:00 rclone /usr/sbin/cron[35709]: (root) CMD (root /bin/sh -x /usr/share/RcloneBzSync.sh >/var/log/cron.txt 2>&1)
Aug 22 14:32:00 rclone /usr/sbin/cron[35739]: (root) CMD (/usr/share/test.sh 2>&1 >/var/log/test.txt)
Aug 22 14:32:00 rclone /usr/sbin/cron[35740]: (root) CMD (root /bin/sh -x /usr/share/RcloneBzSync.sh >/var/log/cron.txt 2>&1)
Aug 22 14:33:00 rclone /usr/sbin/cron[35782]: (root) CMD (/usr/share/test.sh 2>&1 >/var/log/test.txt)
Aug 22 14:33:00 rclone /usr/sbin/cron[35781]: (root) CMD (root /bin/sh -x /usr/share/RcloneBzSync.sh >/var/log/cron.txt 2>&1)
Aug 22 14:35:38 rclone crontab[36006]: (root) BEGIN EDIT (root)
Aug 22 14:37:38 rclone crontab[36006]: (root) END EDIT (root)
Aug 22 15:51:23 rclone crontab[39287]: (root) BEGIN EDIT (root)
Aug 22 15:51:36 rclone crontab[39287]: (root) REPLACE (root)
Aug 22 15:51:37 rclone crontab[39287]: (root) END EDIT (root)
Aug 22 15:55:00 rclone crontab[39462]: (root) BEGIN EDIT (root)
Aug 22 15:55:46 rclone crontab[39462]: (root) REPLACE (root)
Aug 22 15:55:47 rclone crontab[39462]: (root) END EDIT (root)
Aug 22 15:55:48 rclone crontab[39581]: (root) BEGIN EDIT (root)
Aug 22 15:55:52 rclone crontab[39581]: (root) END EDIT (root)
Aug 22 15:56:38 rclone crontab[39602]: (root) BEGIN EDIT (root)
Aug 22 15:56:47 rclone crontab[39602]: (root) END EDIT (root)
fracai
So cron (/var/log/test.txt?) shows the script being run every minute. I'm presuming the other file (/var/log/test.txt) shows nothing?
fracai
Try just the following command in the crontab: env > /var/log/env.txt
Also, did the previous attempt include a newline at the end? I recently saw the lack of that as a reason for a cron job not running.
babaz83
Hi thank you again for your support.
Unfortunately I did try all the tests you've suggested but nothing happen, no file is generated or filled.
The only result I have is the defaut cron log that I've showed you on the previous post.
This what I have inside crontab
root@rclone:/var/log # crontab -l
SHELL=/bin/sh
PATH=/usr/share:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
* * * * * env > /var/log/env.txt
* * * * * sh -x /usr/share/RcloneBzSync.sh
0 0 * * * root /usr/local/sbin/anacron
If you like I can give access through teamviewer I really don't know how to fix this.
fracai
I'd be willing to try teamviewer or skype. I'll send a message to see if we can set something up.
