microbug
- Dec 14, 2016
Hi all,
I'm experiencing a strange issue with my main pool. Details:
When using the pool via a remote client (SMB), transfers are around 100MB/s which is about expected (given that there are a couple of switches between the server and client, and the network can be busy with streams etc.). Scrubs run with zpool scrub <pool> are running at 500MB/s according to zpool status -v <pool>. During scrubs the disks are reading at around 100MB/s each, as expected.
However, file duplication runs very slowly. Duplicating a folder of large (5-10GB each) video files through cp -av <source> <dest> or rsync -av <source> <dest> runs at around 80MB/s! I know my pool can do better than that. What could the cause be? I've turned off my other server running all services that could be reading/writing from my pool and network activity in FreeNAS's reporting tab is near zero. There is nothing else, as far as I can see, that would be lowering performance. My snapshot policy is one every 10 mins. I don't have any VMs or jails running so the ARC sucks up around 14.5GB of memory once it's been running a while.
Any ideas?
- Pool is 5 * 4TB WD Blue and 1 * 4TB WD Green in RAIDZ1. 5 are attached directly to the motherboard and 1 to a SATA 3 PCIe card.
- 16GB of DDR3 ECC RAM, Xeon E3-1265Lv3
- Gigabit ethernet connection between client and server (only relevant wrt Samba speeds)
- Running FreeNAS-11.0-U4 (54848d13b)
Any ideas?
