Dual NIC motherboard and DMZ jail
trumee
I have the forum recommended motherboard Supermicro X10Sl7-F which has dual NIC. The motherboard is connected to a router and gets the following ip addresses:
Network Summary:
Name IPv4 Address IPv6 Address
igb0 172.18.1.101/24
igb1 192.168.10.105/24
Nameserver
172.18.1.1
Default route
172.18.1.1
I want the jails to use the second (igb1) interface with their gateway defined as 192.168.10.1. This network is my DMZ network. Is this possible?
D
dlavigne
Guest
I believe so. When you create the jail, make sure the VIMAGE box is checked, the desired NIC is selected, and tie down the desired IP address, nameserver, and default gateway.
D
dlavigne
Guest
Does it work with VIMAGE checked and the desired addressing info input manually? ie without selecting the NIC?
trumee
No, it didnt work. I setup things manually as shown in the attached images.
The routing table i get is this:
root@dmz:/ # netstat -rn
Routing tables
Internet:
Destination Gateway Flags Refs Use Netif Expire
default 192.168.10.1 UGS 0 0 epair5
127.0.0.1 link#1 UH 0 0 lo0
192.168.10.0/24 link#2 U 0 0 epair5
192.168.10.15 link#2 UHS 0 0 lo0
Internet6:
Destination Gateway Flags Netif Expire
::/96 ::1 UGRS lo0
::1 link#1 UH lo0
::ffff:0.0.0.0/96 ::1 UGRS lo0
fe80::/10 ::1 UGRS lo0
fe80::%lo0/64 link#1 U lo0
fe80::1%lo0 link#1 UHS lo0
ff01::%lo0/32 ::1 U lo0
ff02::/16 ::1 UGRS lo0
ff02::%lo0/32 ::1 U lo0
and ping to the router or even the host doesnt work
root@dmz:/ # ping 192.168.10.105
PING 192.168.10.105 (192.168.10.105): 56 data bytes
ping: sendto: Host is down
^C
--- 192.168.10.105 ping statistics ---
6 packets transmitted, 0 packets received, 100.0% packet loss
PING 192.168.10.1 (192.168.10.1): 56 data bytes
^C
--- 192.168.10.1 ping statistics ---
root@dmz:/ #
any idea what could be wrong?
Fish
Are both NICs configured in FreeNAS? (Network>Interfaces)
