Downloads not being moved once downloaded
What colour is your fridge
  • White
    Votes: 0 0.0%
  • Black
    Votes: 0 0.0%
  • Blue
    Votes: 0 0.0%
  • Red
    Votes: 0 0.0%
  • Total voters
andrenel212
Hi, every time a download is finished it supposed to move the download to the correct drive, but its not working, i used the following guide to set everything up and it worked when i did it off a VM with no issues. I have since purchases a PC and have installed freenas the same way except that on my shares for moves and series the download dataset for each one is on a different drive (i have attached an image), this is the only difference to my original install where they where on the same drive.
PC Specs
ASUS H61m-c Mobo
i3 3.5ghz
16gb ddr RAM
1x 250gb HDD which OS is installed on
1x 500gb HDD for jails, music and documnets
1x 2tb HDD for series and movies
Thanks
D
dlavigne
Guest
Did you resolve this? If not, which Guide did you use? How did you configure Add Storage?
andrenel212
It's resolved forgot to give jails permissions
