1337Hacker
- Oct 22, 2017
It's about time I start using SSL on FreeNAS and found some great articles on the process:
www.ixsystems.com
www.ixsystems.com
One thing that seems to be overlooked that I do not understand: domains
Is the domain used for anything other than issuing the certification?
Does the domain have to be bound/attached to the FreeNAS server somehow? If so, how?
Can the domain be used for a pre-existing website? With an already issued SSL?
Do you need to keep control over the domain after 3 months for certbot?
I can't seem to find a straight answer regarding this topic. I also do NOT want to allow public IP access to the server. Someone please drop some knowledge!
Let's Encrypt with FreeNAS 11.1 and later
Integrating Let’s Encrypt TLS Certificates with FreeNAS FreeNAS has long had the ability to use HTTPS for the web GUI, but that has usually meant dealing with self-signed certificates and the associated headaches, or paying for a commercial...
HOW-TO: Set up NGINX to reverse proxy your jails w/ Certbot
Disclaimer: -I'm making this guide simply to help other people, i just put together multiple guides found on the internet (which i'll post below). This is meant to be as easy as it gets for a newbie to get NGINX to reverse proxy using https. -What is a reverese proxy...
