mihies
- Jan 6, 2022
So I'm running a docker host on alpine based VM. I wonder what's the best way to access/store data from TrueNAS.
Here is how I see it.
1. One way would be through NFS, but AFAIK that sounds unreliable because of locking issues and what not. On plus side, one can mount datasets.
2. The other way seems to be to add a disk device linked to a zvol directly to VM. This sounds more reliable, but one can't use datasets, just zvols. This can be a problem because zvols required fixed size, but I guess it could be mitigated with using Sparse option (which, I assume, uses only the space on disk that is actually in use).
I'm leaning to second option. Am I missing any other option or something?
