do i need to replace one of my ssds - checksum errors ?
ethereal
hello.
i was working on my freenas and when i finished after i booted` i got an error regarding the boot drive (a mirrored ssd)
i ran a scrub on the boot disc and one of the ssds has 27 checksum errors.
do i need to replace this or was the problem just the data cable not seated correctly ?
Could be... check your SMART data for that drive.
Jailer
Not strong, but bad
From his signature:
Boot Mirror - 2 x Intel SSD 320 Series 40GB
HoneyBadger
actually does care
Administrator
From his signature:
Thank you; mobile still doesn't seem to show it. Those should be fine; seconding the check for SMART data, but reseating the cables wouldn't be bad if you have any reason to suspect them @ethereal
ethereal
i was working on hdds next to them and as the ssds do not latch - i may have moved the cables
ethereal
thank you everybody - did a reboot and everything is okay
Jessep
Do you have scheduled SMART tests and scrubs?
ethereal
