Hello
Just before I go all out and buy all the components to build my nas with the truenas software do I have to be able to write in script or powershell as I am a bit at sea with using script and prefer to use the gui. Would I be able to get help with using script or would you recommend I do not use truenas I am coming from a windows base pc I can use windows dos but this truenas is something much different. If I can use the Gui no problem but if certain emplements require the use of being able to use the script then i would be all at sea. Advice needed before going all out on this nas build. Thank you to all who reply.
