nabsltd
- Jul 1, 2022
I have new hardware that I am going to use for TrueNAS, and installed Core (latest stable), poked around a bit, did some testing, and did not have any problems. But, I read that the plugin system in Core is not nearly as robust as that in Scale, so I pulled my SATADOM, plugged in another one, and installed Scale (also latest stable). The install was a little wonky (it looked like some sort of issue with curses), so I wanted to make sure everything was configured right after it booted.
I tried to run
I tried to run
diskinfo
to see which disk was which (because naming is different between Linux and BSD), and found the command doesn't exist. Is there an equivalent with a different name, or has it just not yet been added to the standard install?
