Lage
 - Aug 7, 2013
Hi!
I have got a problem with my FreeNAS system. The problem arose when I was going to replace a mirror of disks with another pair. I have searched the forum and the rest of the web, but not quite found anybody having had the same problem.
Setup:
zpool import won't let me import the pool, however, zpool import -V shows me the following:
As far as I'm concerned, 12093535385621290284 should refer to the new drive.
If it's any help, here's the output from gpart status:
and gpart list gives me:
Please help!
Setup:
- FreeNAS-8.3.1-RELEASE-p2-x64 (r12686+b770da6_dirty), on a USB stick.
 - 2 * 2 TB disks, mirrored
 - 2 * 500 GB disks, mirrored
 - One zpool in the system, consisting of both vdevs.
- Physically removed one of the 500 GB drives.
 - Physically attached another drive. Started machine.
 - (gpart new drive as desired)
 - zpool replace <pool> <old_drive> <new_drive>
 - Resilver finished.
- zpool detach <pool> <old_drive>
 - Zpool in degraded, but functioning, state (as expected).
 - Turned machine off and physically removed remaining 500GB drive.
 - Started machine.
zpool import -V
  pool: brumund
  state: UNAVAIL
status: One or more devices are missing from the system.
action: The pool cannot be imported. Attach the missing
        devices and try again.
  see: http://www.sun.com/msg/ZFS-8000-3C
        brumund                                        UNAVAIL  insufficient replicas
          mirror-0                                      ONLINE
            gptid/1df5b952-9149-11e1-813a-00261802e7bd  ONLINE
            gptid/263a6d98-9149-11e1-813a-00261802e7bd  ONLINE
          12093535385621290284                          UNAVAIL  cannot open
gpart status Name Status Components ada0p1 OK ada0 ada0p2 OK ada0 ada1p1 OK ada1 ada1p2 OK ada1 ada2p1 OK ada2 ada2p2 OK ada2 ada3p1 OK ada3 ada3p2 OK ada3 da0s1 OK da0 da0s2 OK da0 da0s3 OK da0 da0s4 OK da0 da0s1a OK da0s1 da0s2a OK da0s2
Geom name: ada0 modified: false state: OK fwheads: 16 fwsectors: 63 last: 3907029134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada0p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1 rawuuid: 4470865a-9147-11e1-89df-00261802e7bd rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada0p2 Mediasize: 1998251367936 (1.8T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: 263a6d98-9149-11e1-813a-00261802e7bd rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 1998251367936 offset: 2147549184 type: freebsd-zfs index: 2 end: 3907029134 start: 4194432 Consumers: 1. Name: ada0 Mediasize: 2000398934016 (1.8T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 Geom name: ada1 modified: false state: OK fwheads: 16 fwsectors: 63 last: 3907029134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada1p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1 rawuuid: c985c7c1-9148-11e1-813a-00261802e7bd rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada1p2 Mediasize: 1998251367936 (1.8T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: 1df5b952-9149-11e1-813a-00261802e7bd rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 1998251367936 offset: 2147549184 type: freebsd-zfs index: 2 end: 3907029134 start: 4194432 Consumers: 1. Name: ada1 Mediasize: 2000398934016 (1.8T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 Geom name: ada2 modified: false state: OK fwheads: 16 fwsectors: 63 last: 1953525134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada2p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1 rawuuid: 9f4a4e10-ff4c-11e2-bced-00261802e7bd rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada2p2 Mediasize: 996432412672 (928G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: 5c4b488f-ff4d-11e2-bced-00261802e7bd rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 996432412672 offset: 2147549184 type: freebsd-zfs index: 2 end: 1950351487 start: 4194432 Consumers: 1. Name: ada2 Mediasize: 1000204886016 (931G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 Geom name: ada3 modified: false state: OK fwheads: 16 fwsectors: 63 last: 976773134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada3p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 65536 Mode: r1w1e1 rawuuid: 0e5bdc3d-f1d1-11e1-81c0-00261802e7bd rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada3p2 Mediasize: 497960295936 (463G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 2147549184 Mode: r0w0e0 rawuuid: 0e6c87c5-f1d1-11e1-81c0-00261802e7bd rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 497960295936 offset: 2147549184 type: freebsd-zfs index: 2 end: 976773134 start: 4194432 Consumers: 1. Name: ada3 Mediasize: 500107862016 (465G) Sectorsize: 512 Mode: r1w1e2 Geom name: da0 modified: false state: OK fwheads: 255 fwsectors: 63 last: 7821311 first: 63 entries: 4 scheme: MBR Providers: 1. Name: da0s1 Mediasize: 988291584 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 32256 Mode: r1w0e1 attrib: active rawtype: 165 length: 988291584 offset: 32256 type: freebsd index: 1 end: 1930319 start: 63 2. Name: da0s2 Mediasize: 988291584 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 988356096 Mode: r0w0e0 rawtype: 165 length: 988291584 offset: 988356096 type: freebsd index: 2 end: 3860639 start: 1930383 3. Name: da0s3 Mediasize: 1548288 (1.5M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 1976647680 Mode: r0w0e0 rawtype: 165 length: 1548288 offset: 1976647680 type: freebsd index: 3 end: 3863663 start: 3860640 4. Name: da0s4 Mediasize: 21159936 (20M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 1978195968 Mode: r1w1e2 rawtype: 165 length: 21159936 offset: 1978195968 type: freebsd index: 4 end: 3904991 start: 3863664 Consumers: 1. Name: da0 Mediasize: 4004511744 (3.7G) Sectorsize: 512 Mode: r2w1e4 Geom name: da0s1 modified: false state: OK fwheads: 255 fwsectors: 63 last: 1930256 first: 0 entries: 8 scheme: BSD Providers: 1. Name: da0s1a Mediasize: 988283392 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 40448 Mode: r1w0e1 rawtype: 0 length: 988283392 offset: 8192 type: !0 index: 1 end: 1930256 start: 16 Consumers: 1. Name: da0s1 Mediasize: 988291584 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 32256 Mode: r1w0e1 Geom name: da0s2 modified: false state: OK fwheads: 255 fwsectors: 63 last: 1930256 first: 0 entries: 8 scheme: BSD Providers: 1. Name: da0s2a Mediasize: 988283392 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 988364288 Mode: r0w0e0 rawtype: 0 length: 988283392 offset: 8192 type: !0 index: 1 end: 1930256 start: 16 Consumers: 1. Name: da0s2 Mediasize: 988291584 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 988356096 Mode: r0w0e0
Please help!
