disk replacement
HRS
Hi
I have a raidz2 array of 6 WD Red 3TB drives.
I've recently upgraded the system (replaced the mother board) and upgraded to FreeNas 11.
I am receiving the following error:
"The volume volume1 state is DEGRADED: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected."
tried clearing the error (zpool clear volume_name), followed by scrubbing the pool but the error message returns.
when I run 'zpool status -v', i get the following:
pool: volume1
state: DEGRADED
status: One or more devices has experienced an unrecoverable error. An
see: http://illumos.org/msg/ZFS-8000-9P
scan: scrub repaired 8.51M in 3h22m with 0 errors on Wed Aug 9 06:26:26 2017
NAME STATE READ WRITE CKSUM
volume1 DEGRADED 0 0 0
raidz2-0 DEGRADED 0 0 0
gptid/c890406f-13f8-11e4-a66e-d05099192b2f ONLINE 0 0 0
gptid/82bfc1d7-1c29-11e4-bce1-d05099192b2f ONLINE 0 0 0
gptid/ca2fd8e8-13f8-11e4-a66e-d05099192b2f ONLINE 0 0 0
gptid/cb0ef8de-13f8-11e4-a66e-d05099192b2f ONLINE 0 0 40
gptid/cbddf557-13f8-11e4-a66e-d05099192b2f DEGRADED 0 0 1.50K too many errors
gptid/ccadec6b-13f8-11e4-a66e-d05099192b2f ONLINE 0 0 0
errors: No known data errors
1. Does it mean that the drive has to be replaced?
2. Identifying the failed disk - should I follow the procedure outlined in this link?
3. What is the exact procedure required for disk replacement? (do I need to reattach the new drive? resilver?) please send the list of commands
4. Could I replace the 3TB drive with a 4TB or 6TB, even if only 3TB would be currently used, so that when other drives will be replaced in the future the capacity could be increased?
Spud
Hi
Open a shell and see what smartctl -A /dev/the_drive_in_question
And yes you can replace the 3TB drive with a larger drive.
smartctl -a /dev/adawhatever
Uppercase "A" trims out too much useful information.
nojohnny101
HRS
Thanks all
I've experienced a "miracle". The drive seems to have returned to life.
It is strange. After a couple of days of consistent drive errors, it suddenly went away and the system is "green" for last few days.
Anyway, thanks to all of you I know what to do when the errors return
And, Spud, you mentioned that I can replace drives to larger drives.
Coud you describe what happens to the 6 drive raidz2 pool as drives are replaced incrementally (e.g. 3TB with 4TB or 6TB)
Nothing until the last drive is replaced; when the last drive is replaced, the vdev's (and thus the pool's) capacity increases accordingly.
Spud
Thanks all
One other thing to check before you start replacing the drives is "zpool get autoexpand" make sure its on.
Stux
Thanks all
This is a good time to refresh your backups, before the drive gives up the ghost for good...
And you should provide the requested smartctl info too...
Once all drives are replaced, the vdev will automatically expand (assuming autoexpand property is set to the default of true). It expands based on the smallest drive in the vdev, so if you have 3TB drives, replace half with 4TB drives, and the rest with 6TB drives, then the vdev will autoexpand as if all drives were 4TB. When the 4TB drives are then replaced with 6TB drives, it will again expand.
