Gorf
- Jan 5, 2017
v2.4.4. For the second time now Snort alerts have hammered the drive and filled it up to capacity. I manage to remove older logs but I have two issues at hand. The first is that when this occurs, the Dashboard disappears. It just shows the menu at the top, then "Status/Dashboard" and nothing else. Bonus, the Snort option also disappears from the menu. I have gone into the console and restarted the webConfigurator and the php-fpm process but it doesn't resolve the issue. The results are consistent across multiple browsers. The only way to get everything back to normal is to reboot the system which isn't idea but it gets the job done. Is there another way to work around this issue if it happens again?
The reason I ask is because the Snort Log MGMT settings page is goofy at best. It doesn't seem to obey the Log Directory Size config parameter and often reverts back to some funky value like -1819 or something.
Thoughts?
Thoughts?
