Luca Prete
- Sep 1, 2015
Hello everyone,
Does anyone have experienced any other issue like this one? I'm running in the same problem, but going through the steps above didn't help.
This is my config:
- LSI SAS 9201 - 16i - firmware version 16 (corresponding to the driver version running in Freenas)
- FreeNAS 9.3 (latest stable downloaded from the website)
The problem I've is the following:
- When I do CTRL+C at startup and I go in the config utility I see drives in the correct order
- When I install freenas I see drivers in the wrong order. I anyway select the two drives that I would like to use for the installation
- After installing FreeNAS I go in the GUI and the drives have another order again! The worst thing is that I see again in the list of available devices my two devices where I supposed to have install the system...and other two (that actually should be empty instead) have the OS installed.
Not sure it's that clear..but let me know if I can provide any other info/clarification.
Looking forward to receiving news on this
Thanks
mod note: edited for link to old post
This is my config:
Thanks
