Different Results from "df -h" and FreeNAS UI
Fabio Rodrigues
If I run df-h in the FreeNAS server, it says that only 4GB is in use, but if I check the volume in the UI, it says that 6GB is in use. I checked and this additional 2GB is not being used by snapshots.
Is it still a known issue? What information should I trust, df or UI? Is there a way to check what is this additional 2GB?
Regards!
