ChristianGrebe
- Nov 22, 2017
maybe a dumb question, but I could not find an exact answer to my problem.
I would like to replace a SATA disk in my system (see signature). My system has no hot-swap capability and no free disk bays or ports.
Is the suggested procedure as follows?:
Regards,
Christian
- Offline the old disk to be replaced.
- Optional shut down the system if no hot-swap capability?
- Physically remove the old disk.
- Physically install the new disk on the same SATA port as the old disk.
- Optional turn on the system?
- Replace old disk with new one in Pool Status.
ada0 with a new disk at ada0, which sounds kind of odd.Regards,
Christian
