I'm looking for a controller to put in a proliant DL380 G6 to replace the integrated P410i controller.
I could get for about 50€ a Dell perc h200 that could be flashed to LSI 9211-8i.
I also found some M1015 bit a bit more expensive (about 70€).
My question: can I get the cheaper one (i.e. the perc h200) and flash it. Or shall I rather go for a M1015 (but it's the same hardware-wise isn't it? and it will require some flashing too as well if I'm correct?)?
I'll have to check the PCIe ports available in the server to see if the card fits of course... ;-)
Thanks.
Thanks.
