Delete disk from stripe
elangley
Hello All,
I inadvertently added a disk to a volume as a stripe instead of mirror.
Is there a way to remove it and if so how?
FreeNAS 9.10.2-U6
Thanks in advance,
~eric
kdragon75
Nope. You will have to backup and rebuild the pool.
Redcoat
zpool remove [-np] pool device ...
man zpool for more detail.
@danb35 , does that command work for a disk removal today? I just read the detailed description and could not conclude that it covered disks presently. Or is there more promising explanation somewhere else?
Redcoat
I believe that comes in with 11.2. It isn't there in 11.1.
I have 11.2-RC2 up and that's where I looked. Perhaps it's coming in the final release.
No, zpool remove should work in 11.2-RC2. But it only works when all vdevs in the pool are either single disks or mirrors.
