Degraded zpool
sdspieg
My zpool is degraded and I can't get into the GUI anymore. That is - I see the 'right side' of the GUI, but the left side nevers fully loads. The system seems to boot properly and loads two plugins but then gets stuck on a second. There seems to be a certain period during the bootup process when I can still get into the full GUI (also left) and start a shell. When I then do a zpool status I see that 2 of my four disks are UNAVAIL. IT also resilvers sthg, but when that is done, I still can't get into the system. When I reboot, it just starts resilvering again.
  scan: resilver in progress since Tue Mar 11 03:45:17 2014
        55.7G scanned out of 1.34T at 190M/s, 1h58m to go
        90.1M resilvered, 4.06% done
        NAME                                            STATE    READ WRITE CKS
UM
        StephanNAS                                      DEGRADED    1    0
0
          mirror-0                                      DEGRADED    2    0
0
            9124370631216349259                        UNAVAIL      0    0
0  was /dev/gptid/d65eb91c-5201-11e2-87a9-3085a943b0e3
            gptid/d6bde0bf-5201-11e2-87a9-3085a943b0e3  ONLINE      0    0
2  (resilvering)
          mirror-1                                      DEGRADED    0    0
0
            gptid/ebe6f24f-59ae-11e3-a143-3085a943b0e3  ONLINE      0    0
0
            11534118553952820132                        UNAVAIL      0    0
0  was /dev/gptid/98526e0f-526e-11e2-bbec-3085a943b0e3
errors: 14 data errors, use '-v' for a list
[root@freenas ~]#
Any ideas about what I can do? It still somehow sees the 1.34 T that are (kind of) important to me (although I do have backups that I could get back onto the NAS if need be).
Thanks!
-Stephan
Well, you 've got no redundancy to your pool, and if you do a -v you'll see you have corrupt files too!
If your backups are thorough and complete I'd destroy your pool and recreate it from backup.
sdspieg
Thanks. And what would you recommend for the setup (these are 4 3T drives) - raid z2?
Oh and btw - I did take a look at the corrupt files, and they are non-essential ones. So is there any way I could at least still 'look' at the ones that are NOT corrupt?
-Stephan
