So it looks like one of my disks is having some problems. I want to make sure I have done everything I can before returning the disk
AND
The I/O graph in the GUI show zero activity on /dev/da4.
Is there anything more I can do before replacing the disk?
[root@freenas] ~# zpool status
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0h1m with 0 errors on Mon Mar 9 03:46:15 2015
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
da0p2 ONLINE 0 0 0
errors: No known data errors
pool: media_z1
state: DEGRADED
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://illumos.org/msg/ZFS-8000-8A
scan: scrub repaired 4.19M in 54h8m with 1 errors on Tue Mar 17 06:08:34 2015
media_z1 DEGRADED 0 0 98
raidz1-0 DEGRADED 0 0 393
gptid/fd4d0102-8df7-11e4-b14b-0050569e84ab DEGRADED 0 0 1 too many errors
gptid/fdbee6c9-8df7-11e4-b14b-0050569e84ab FAULTED 38 174 23 too many errors
gptid/fe2cd4d9-8df7-11e4-b14b-0050569e84ab DEGRADED 0 0 0 too many errors
gptid/fe96e576-8df7-11e4-b14b-0050569e84ab ONLINE 0 0 0
gptid/ff01f236-8df7-11e4-b14b-0050569e84ab DEGRADED 0 0 0 too many errors
errors: 3 data errors, use '-v' for a listAND
[root@freenas] ~# gpart list Geom name: da0 modified: false state: OK fwheads: 255 fwsectors: 63 last: 20971486 first: 34 entries: 128 scheme: GPT Providers: 1. Name: da0p1 Mediasize: 524288 (512k) Sectorsize: 512 Stripesize: 0 Stripeoffset: 17408 Mode: r0w0e0 rawuuid: fee8da13-8df7-11e4-8b56-0050569e84ab rawtype: 21686148-6449-6e6f-744e-656564454649 label: (null) length: 524288 offset: 17408 type: bios-boot index: 1 end: 1057 start: 34 2. Name: da0p2 Mediasize: 10736852992 (10G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 544768 Mode: r1w1e1 rawuuid: fef5230a-8df7-11e4-8b56-0050569e84ab rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 10736852992 offset: 544768 type: freebsd-zfs index: 2 end: 20971479 start: 1064 Consumers: 1. Name: da0 Mediasize: 10737418240 (10G) Sectorsize: 512 Mode: r1w1e2 Geom name: da1 modified: false state: OK fwheads: 255 fwsectors: 63 last: 5860533134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: da1p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1 rawuuid: fe18c494-8df7-11e4-b14b-0050569e84ab rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: da1p2 Mediasize: 2998445412352 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 rawuuid: fe2cd4d9-8df7-11e4-b14b-0050569e84ab rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2998445412352 offset: 2147549184 type: freebsd-zfs index: 2 end: 5860533127 start: 4194432 Consumers: 1. Name: da1 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r2w2e5 Geom name: da2 modified: false state: OK fwheads: 255 fwsectors: 63 last: 5860533134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: da2p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1 rawuuid: feee2b05-8df7-11e4-b14b-0050569e84ab rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: da2p2 Mediasize: 2998445412352 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 rawuuid: ff01f236-8df7-11e4-b14b-0050569e84ab rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2998445412352 offset: 2147549184 type: freebsd-zfs index: 2 end: 5860533127 start: 4194432 Consumers: 1. Name: da2 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r2w2e5 Geom name: da3 modified: false state: OK fwheads: 255 fwsectors: 63 last: 5860533134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: da3p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1 rawuuid: fe8269c7-8df7-11e4-b14b-0050569e84ab rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: da3p2 Mediasize: 2998445412352 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 rawuuid: fe96e576-8df7-11e4-b14b-0050569e84ab rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2998445412352 offset: 2147549184 type: freebsd-zfs index: 2 end: 5860533127 start: 4194432 Consumers: 1. Name: da3 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r2w2e5 Geom name: da4 modified: false state: OK fwheads: 255 fwsectors: 63 last: 5860533134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: da4p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1 rawuuid: fdab6243-8df7-11e4-b14b-0050569e84ab rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: da4p2 Mediasize: 2998445412352 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 rawuuid: fdbee6c9-8df7-11e4-b14b-0050569e84ab rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2998445412352 offset: 2147549184 type: freebsd-zfs index: 2 end: 5860533127 start: 4194432 Consumers: 1. Name: da4 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r2w2e5 Geom name: da5 modified: false state: OK fwheads: 255 fwsectors: 63 last: 5860533134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: da5p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1 rawuuid: fd389ead-8df7-11e4-b14b-0050569e84ab rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: da5p2 Mediasize: 2998445412352 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 rawuuid: fd4d0102-8df7-11e4-b14b-0050569e84ab rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2998445412352 offset: 2147549184 type: freebsd-zfs index: 2 end: 5860533127 start: 4194432 Consumers: 1. Name: da5 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r2w2e5
