Defective Hard Disk? Device: /dev/ada0, 1536 Currently unreadable (pending) sectors
frozn00
I am running FreeNAS-9.3-STABLE-201501162230 and I am getting this below:
Jun  2 00:00:00 freenas newsyslog[65317]: logfile turned over due to size>100K
Jun  2 00:00:00 freenas syslog-ng[29101]: Configuration reload request received, reloading configuration;
Jun  2 00:29:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Currently unreadable (pending) sectors
Jun  2 00:29:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Offline uncorrectable sectors
Jun  2 00:59:22 freenas smartd[2242]: Device: /dev/ada0, 1536 Currently unreadable (pending) sectors
Jun  2 00:59:22 freenas smartd[2242]: Device: /dev/ada0, 1536 Offline uncorrectable sectors
Jun  2 01:29:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Currently unreadable (pending) sectors
Jun  2 01:29:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Offline uncorrectable sectors
Jun  2 01:59:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Currently unreadable (pending) sectors
Jun  2 01:59:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Offline uncorrectable sectors
Jun  2 02:29:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Currently unreadable (pending) sectors
Jun  2 02:29:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Offline uncorrectable sectors
Jun  2 02:59:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Currently unreadable (pending) sectors
Jun  2 02:59:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Offline uncorrectable sectors
Jun  2 03:06:08 freenas freenas[70824]: Traceback (most recent call last):
Jun  2 03:06:08 freenas freenas[70824]:   File "/usr/local/www/freenasUI/common/system.py", line 179, in send_mail
Jun  2 03:06:08 freenas freenas[70824]:     local_hostname=local_hostname)
Jun  2 03:06:08 freenas freenas[70824]:   File "/usr/local/lib/python2.7/smtplib.py", line 251, in __init__
Jun  2 03:06:08 freenas freenas[70824]:     (code, msg) = self.connect(host, port)
Jun  2 03:06:08 freenas freenas[70824]:   File "/usr/local/lib/python2.7/smtplib.py", line 312, in connect
Jun  2 03:06:08 freenas freenas[70824]:     (code, msg) = self.getreply()
Jun  2 03:06:08 freenas freenas[70824]:   File "/usr/local/lib/python2.7/smtplib.py", line 360, in getreply
Jun  2 03:06:08 freenas freenas[70824]:     + str(e))
Jun  2 03:06:08 freenas freenas[70824]: SMTPServerDisconnected: Connection unexpectedly closed: timed out
Jun  2 03:29:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Currently unreadable (pending) sectors
Jun  2 03:29:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Offline uncorrectable sectors
Jun  2 03:59:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Currently unreadable (pending) sectors
Jun  2 03:59:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Offline uncorrectable sectors
Jun  2 04:29:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Currently unreadable (pending) sectors
Jun  2 04:29:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Offline uncorrectable sectors
Jun  2 04:59:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Currently unreadable (pending) sectors
Jun  2 04:59:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Offline uncorrectable sectors
Jun  2 05:29:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Currently unreadable (pending) sectors
Jun  2 05:29:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Offline uncorrectable sectors
Jun  2 05:59:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Currently unreadable (pending) sectors
Jun  2 05:59:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Offline uncorrectable sectors
Jun  2 06:29:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Currently unreadable (pending) sectors
Jun  2 06:29:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Offline uncorrectable sectors
Jun  2 06:59:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Currently unreadable (pending) sectors
Jun  2 06:59:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Offline uncorrectable sectors
Jun  2 07:29:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Currently unreadable (pending) sectors
Jun  2 07:29:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Offline uncorrectable sectors
Jun  2 07:59:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Currently unreadable (pending) sectors
Jun  2 07:59:23 freenas smartd[2242]: Device: /dev/ada0, 1536 Offline uncorrectable sectors
Jun  2 08:29:22 freenas smartd[2242]: Device: /dev/ada0, 1536 Currently unreadable (pending) sectors
Jun  2 08:29:22 freenas smartd[2242]: Device: /dev/ada0, 1536 Offline uncorrectable sectors
I ran smartctl -q noserial -a /dev/ada0 as shown in this post:
https://forums.freenas.org/index.php?threads/defective-hard-disk.14196/
and I got:
[root@freenas] ~# smartctl -q noserial -a /dev/ada0
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p8 amd64] (local build)
Model Family:     Seagate Barracuda 7200.14 (AF)
Device Model:     ST3000DM001-9YN166
Firmware Version: CC4H
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Rotation Rate:    7200 rpm
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Tue Jun  2 08:34:34 2015 EDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  584) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 334) minutes.
Conveyance self-test routine
SCT capabilities:              (0x3085) SCT Status supported.
  1 Raw_Read_Error_Rate     0x000f   119   089   006    Pre-fail  Always       -       210306512
  3 Spin_Up_Time            0x0003   094   092   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       123
  5 Reallocated_Sector_Ct   0x0033   052   051   036    Pre-fail  Always       -       63192
  7 Seek_Error_Rate         0x000f   079   060   030    Pre-fail  Always       -       4394811424
  9 Power_On_Hours          0x0032   077   077   000    Old_age   Always       -       20841
10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       122
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   012   012   000    Old_age   Always       -       88
188 Command_Timeout         0x0032   100   092   000    Old_age   Always       -       9 9 9
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   065   060   045    Old_age   Always       -       35 (Min/Max 19/38)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       113
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       1180
194 Temperature_Celsius     0x0022   035   040   000    Old_age   Always       -       35 (0 19 0 0 0)
197 Current_Pending_Sector  0x0012   091   091   000    Old_age   Always       -       1536
198 Offline_Uncorrectable   0x0010   091   091   000    Old_age   Offline      -       1536
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       20630h+46m+25.931s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       55736613594934
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       246332895966913
SMART Error Log Version: 1
ATA Error Count: 84 (device log contains only the most recent five errors)
        CR = Command Register [HEX]
        FR = Features Register [HEX]
        ER = Error register [HEX]
        ST = Status register [HEX]
Error 84 occurred at disk power-on lifetime: 20450 hours (852 days + 2 hours)
  ER ST SC SN CL CH DH
  40 51 00 ff ff ff 0f  Error: UNC at LBA = 0x0fffffff = 268435455
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  60 00 b0 ff ff ff 4f 00  40d+08:17:47.995  READ FPDMA QUEUED
  60 00 b0 ff ff ff 4f 00  40d+08:17:47.994  READ FPDMA QUEUED
  2f 00 01 10 00 00 00 00  40d+08:17:47.959  READ LOG EXT
  60 00 b0 ff ff ff 4f 00  40d+08:17:45.428  READ FPDMA QUEUED
  60 00 b0 ff ff ff 4f 00  40d+08:17:45.427  READ FPDMA QUEUED
Error 83 occurred at disk power-on lifetime: 20450 hours (852 days + 2 hours)
  2f 00 01 10 00 00 00 00  40d+08:17:45.392  READ LOG EXT
  60 00 b0 ff ff ff 4f 00  40d+08:17:42.836  READ FPDMA QUEUED
  60 00 b0 ff ff ff 4f 00  40d+08:17:42.835  READ FPDMA QUEUED
Error 82 occurred at disk power-on lifetime: 20450 hours (852 days + 2 hours)
  2f 00 01 10 00 00 00 00  40d+08:17:42.799  READ LOG EXT
  60 00 b0 ff ff ff 4f 00  40d+08:17:40.252  READ FPDMA QUEUED
  60 00 b0 ff ff ff 4f 00  40d+08:17:40.251  READ FPDMA QUEUED
Error 81 occurred at disk power-on lifetime: 20450 hours (852 days + 2 hours)
  2f 00 01 10 00 00 00 00  40d+08:17:40.216  READ LOG EXT
  60 00 58 ff ff ff 4f 00  40d+08:17:37.650  READ FPDMA QUEUED
  60 00 08 ff ff ff 4f 00  40d+08:17:37.649  READ FPDMA QUEUED
Error 80 occurred at disk power-on lifetime: 20450 hours (852 days + 2 hours)
  60 00 58 ff ff ff 4f 00  40d+08:17:37.610  READ FPDMA QUEUED
  60 00 08 ff ff ff 4f 00  40d+08:17:37.610  READ FPDMA QUEUED
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
[root@freenas] ~#
This is all Greek to me. Can anyone help me? Do I have a defective disk? Thanks for your time.
Bidule0hm
Server Electronics Sorcerer
Well, this drive is simply failing. Replace it accordingly to the manual instructions ;)
Yes, you have a very defective disk. You also aren't running SMART tests, which may have helped you determine that sooner. Once you replace the disk following the manual's instructions, make sure you set up SMART tests on all your disks, with a long test at least every couple of weeks.
frozn00
Thanks for your help guys. Are the SMART tests something I can setup within freenas or is it that I have to power down the system and run it outside of freenas?
frozn00
I see the option under freenas in Tasks >>S.M.A.R.T Tests. There is a test that says Short Self-Test, Every Hour, Everyday, Every Month, Sunday. This is confusing to me. Does that mean it is doing it every hour? Was my system already running S.M.A.R.T tests?
frozn00
Within FreeNAS--it's in the manual, under the heading on Tasks.
Thanks. I will get the drive replaced and refer to the manual for the best practices about setting up the SMART tasks. Is the ZPOOL scrub not sufficient?
They do different things. The SMART tests run directly on the drive hardware, and the long test checks the entire disk, rather than just the used portions (which is what the scrub does). However, the SMART tests have no way to find silent data corruption. You should run both. I run a short SMART test daily, and a long test weekly, which is probably excessive but not egregiously so. A short test weekly and long test monthly is about as far as I'd want to stretch it.
jgreco
Resident Grinch
You can run shorts a lot more frequently than that, like every four or six hours.
Do they actually find anything, or do they only serve to retrigger warning emails and error messages regarding problems identified during normal use or Long tests?
I run Short tests daily because why not, they're painless.
jgreco
Resident Grinch
They're not SUPPOSED to find anything. What a strange question!
When they do find something, it is likely to be more quickly than a less frequent check. That's really the point.
Noobs.. I got a cronjob, and I run short tests every 5 minutes! ;)
You need a dayjob.
I got one, thank you very much!
I have to read my SMART results from the last round of SMART tests... just in time for the next round of tests to finish so I can review those. :P
frozn00
I replaced the drive /dev/ada0 last night with a new 3TB WD Red. Running smartctl -q noserial -a /dev/ada0 now shows the following:
Model Family:     Western Digital Red (AF)
Device Model:     WDC WD30EFRX-68EUZN0
Firmware Version: 80.00A80
Rotation Rate:    5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
Local Time is:    Wed Jun  3 09:28:12 2015 EDT
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (40080) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 402) minutes.
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x703d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   100   253   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   100   253   021    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       2
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       14
10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       2
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       1
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       3
194 Temperature_Celsius     0x0022   121   118   000    Old_age   Always       -       29
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   100   253   000    Old_age   Offline      -       0
No Errors Logged
frozn00
Does this status looks normal now? It appears to to me as it resilvered last night and I checked this morning and I am showing (on what appears to be drive ada1:
Jun  2 18:44:32 freenas ada0: Serial Number WD-WMC4N0793924
Jun  2 18:44:32 freenas ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
Jun  2 18:44:32 freenas ada0: Command Queueing enabled
Jun  2 18:44:32 freenas ada0: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
Jun  2 18:44:32 freenas ada0: quirks=0x1<4K>
Jun  2 18:44:32 freenas ada0: Previously was known as ad4
Jun  2 18:44:47 freenas notifier: 1+0 records in
Jun  2 18:44:47 freenas notifier: 1+0 records out
Jun  2 18:44:47 freenas notifier: 1048576 bytes transferred in 0.697523 secs (1503285 bytes/sec)
Jun  2 18:44:47 freenas notifier: dd: /dev/ada0: short write on character device
Jun  2 18:44:47 freenas notifier: dd: /dev/ada0: end of device
Jun  2 18:44:47 freenas notifier: 5+0 records in
Jun  2 18:44:47 freenas notifier: 4+1 records out
Jun  2 18:44:47 freenas notifier: 4677632 bytes transferred in 0.078445 secs (59629480 bytes/sec)
Jun  2 18:45:00 freenas GEOM_ELI: Device ada0p1.eli created.
Jun  2 18:45:00 freenas GEOM_ELI: Encryption: AES-XTS 128
Jun  2 18:45:00 freenas GEOM_ELI:     Crypto: software
Jun  2 18:45:03 freenas freenas[42596]: Traceback (most recent call last):
Jun  2 18:45:03 freenas freenas[42596]:   File "/usr/local/www/freenasUI/common/system.py", line 179, in send_mail
Jun  2 18:45:03 freenas freenas[42596]:     local_hostname=local_hostname)
Jun  2 18:45:03 freenas freenas[42596]:   File "/usr/local/lib/python2.7/smtplib.py", line 251, in __init__
Jun  2 18:45:03 freenas freenas[42596]:     (code, msg) = self.connect(host, port)
Jun  2 18:45:03 freenas freenas[42596]:   File "/usr/local/lib/python2.7/smtplib.py", line 312, in connect
Jun  2 18:45:03 freenas freenas[42596]:     (code, msg) = self.getreply()
Jun  2 18:45:03 freenas freenas[42596]:   File "/usr/local/lib/python2.7/smtplib.py", line 360, in getreply
Jun  2 18:45:03 freenas freenas[42596]:     + str(e))
Jun  2 18:45:03 freenas freenas[42596]: SMTPServerDisconnected: Connection unexpectedly closed: timed out
Jun  2 18:45:09 freenas freenas[2530]: Traceback (most recent call last):
Jun  2 18:45:09 freenas freenas[2530]:   File "/usr/local/www/freenasUI/../freenasUI/common/system.py", line 179, in send_mail
Jun  2 18:45:09 freenas freenas[2530]:     local_hostname=local_hostname)
Jun  2 18:45:09 freenas freenas[2530]:   File "/usr/local/lib/python2.7/smtplib.py", line 251, in __init__
Jun  2 18:45:09 freenas freenas[2530]:     (code, msg) = self.connect(host, port)
Jun  2 18:45:09 freenas freenas[2530]:   File "/usr/local/lib/python2.7/smtplib.py", line 312, in connect
Jun  2 18:45:09 freenas freenas[2530]:     (code, msg) = self.getreply()
Jun  2 18:45:09 freenas freenas[2530]:   File "/usr/local/lib/python2.7/smtplib.py", line 360, in getreply
Jun  2 18:45:09 freenas freenas[2530]:     + str(e))
Jun  2 18:45:09 freenas freenas[2530]: SMTPServerDisconnected: Connection unexpectedly closed: timed out
Jun  2 18:46:03 freenas freenas[46229]: Traceback (most recent call last):
Jun  2 18:46:03 freenas freenas[46229]:   File "/usr/local/www/freenasUI/common/system.py", line 179, in send_mail
Jun  2 18:46:03 freenas freenas[46229]:     local_hostname=local_hostname)
Jun  2 18:46:03 freenas freenas[46229]:   File "/usr/local/lib/python2.7/smtplib.py", line 251, in __init__
Jun  2 18:46:03 freenas freenas[46229]:     (code, msg) = self.connect(host, port)
Jun  2 18:46:03 freenas freenas[46229]:   File "/usr/local/lib/python2.7/smtplib.py", line 312, in connect
Jun  2 18:46:03 freenas freenas[46229]:     (code, msg) = self.getreply()
Jun  2 18:46:03 freenas freenas[46229]:   File "/usr/local/lib/python2.7/smtplib.py", line 360, in getreply
Jun  2 18:46:03 freenas freenas[46229]:     + str(e))
Jun  2 18:46:03 freenas freenas[46229]: SMTPServerDisconnected: Connection unexpectedly closed: timed out
Jun  2 18:47:03 freenas freenas[46318]: Traceback (most recent call last):
Jun  2 18:47:03 freenas freenas[46318]:   File "/usr/local/www/freenasUI/common/system.py", line 179, in send_mail
Jun  2 18:47:03 freenas freenas[46318]:     local_hostname=local_hostname)
Jun  2 18:47:03 freenas freenas[46318]:   File "/usr/local/lib/python2.7/smtplib.py", line 251, in __init__
Jun  2 18:47:03 freenas freenas[46318]:     (code, msg) = self.connect(host, port)
Jun  2 18:47:03 freenas freenas[46318]:   File "/usr/local/lib/python2.7/smtplib.py", line 312, in connect
Jun  2 18:47:03 freenas freenas[46318]:     (code, msg) = self.getreply()
Jun  2 18:47:03 freenas freenas[46318]:   File "/usr/local/lib/python2.7/smtplib.py", line 360, in getreply
Jun  2 18:47:03 freenas freenas[46318]:     + str(e))
Jun  2 18:47:03 freenas freenas[46318]: SMTPServerDisconnected: Connection unexpectedly closed: timed out
Jun  2 18:48:03 freenas freenas[46410]: Traceback (most recent call last):
Jun  2 18:48:03 freenas freenas[46410]:   File "/usr/local/www/freenasUI/common/system.py", line 179, in send_mail
Jun  2 18:48:03 freenas freenas[46410]:     local_hostname=local_hostname)
Jun  2 18:48:03 freenas freenas[46410]:   File "/usr/local/lib/python2.7/smtplib.py", line 251, in __init__
Jun  2 18:48:03 freenas freenas[46410]:     (code, msg) = self.connect(host, port)
Jun  2 18:48:03 freenas freenas[46410]:   File "/usr/local/lib/python2.7/smtplib.py", line 312, in connect
Jun  2 18:48:03 freenas freenas[46410]:     (code, msg) = self.getreply()
Jun  2 18:48:03 freenas freenas[46410]:   File "/usr/local/lib/python2.7/smtplib.py", line 360, in getreply
Jun  2 18:48:03 freenas freenas[46410]:     + str(e))
Jun  2 18:48:03 freenas freenas[46410]: SMTPServerDisconnected: Connection unexpectedly closed: timed out
Jun  2 18:50:04 freenas freenas[46671]: Traceback (most recent call last):
Jun  2 18:50:04 freenas freenas[46671]:   File "/usr/local/www/freenasUI/common/system.py", line 179, in send_mail
Jun  2 18:50:04 freenas freenas[46671]:     local_hostname=local_hostname)
Jun  2 18:50:04 freenas freenas[46671]:   File "/usr/local/lib/python2.7/smtplib.py", line 251, in __init__
Jun  2 18:50:04 freenas freenas[46671]:     (code, msg) = self.connect(host, port)
Jun  2 18:50:04 freenas freenas[46671]:   File "/usr/local/lib/python2.7/smtplib.py", line 312, in connect
Jun  2 18:50:04 freenas freenas[46671]:     (code, msg) = self.getreply()
Jun  2 18:50:04 freenas freenas[46671]:   File "/usr/local/lib/python2.7/smtplib.py", line 360, in getreply
Jun  2 18:50:04 freenas freenas[46671]:     + str(e))
Jun  2 18:50:04 freenas freenas[46671]: SMTPServerDisconnected: Connection unexpectedly closed: timed out
Jun  2 18:50:09 freenas freenas[2530]: Traceback (most recent call last):
Jun  2 18:50:09 freenas freenas[2530]:   File "/usr/local/www/freenasUI/../freenasUI/common/system.py", line 179, in send_mail
Jun  2 18:50:09 freenas freenas[2530]:     local_hostname=local_hostname)
Jun  2 18:50:09 freenas freenas[2530]:   File "/usr/local/lib/python2.7/smtplib.py", line 251, in __init__
Jun  2 18:50:09 freenas freenas[2530]:     (code, msg) = self.connect(host, port)
Jun  2 18:50:09 freenas freenas[2530]:   File "/usr/local/lib/python2.7/smtplib.py", line 312, in connect
Jun  2 18:50:09 freenas freenas[2530]:     (code, msg) = self.getreply()
Jun  2 18:50:09 freenas freenas[2530]:   File "/usr/local/lib/python2.7/smtplib.py", line 360, in getreply
Jun  2 18:50:09 freenas freenas[2530]:     + str(e))
Jun  2 18:50:09 freenas freenas[2530]: SMTPServerDisconnected: Connection unexpectedly closed: timed out
Jun  2 18:50:15 freenas freenas[2530]: Traceback (most recent call last):
Jun  2 18:50:15 freenas freenas[2530]:   File "/usr/local/www/freenasUI/../freenasUI/common/system.py", line 179, in send_mail
Jun  2 18:50:15 freenas freenas[2530]:     local_hostname=local_hostname)
Jun  2 18:50:15 freenas freenas[2530]:   File "/usr/local/lib/python2.7/smtplib.py", line 251, in __init__
Jun  2 18:50:15 freenas freenas[2530]:     (code, msg) = self.connect(host, port)
Jun  2 18:50:15 freenas freenas[2530]:   File "/usr/local/lib/python2.7/smtplib.py", line 312, in connect
Jun  2 18:50:15 freenas freenas[2530]:     (code, msg) = self.getreply()
Jun  2 18:50:15 freenas freenas[2530]:   File "/usr/local/lib/python2.7/smtplib.py", line 360, in getreply
Jun  2 18:50:15 freenas freenas[2530]:     + str(e))
Jun  2 18:50:15 freenas freenas[2530]: SMTPServerDisconnected: Connection unexpectedly closed: timed out
Jun  2 18:51:05 freenas freenas[48012]: Traceback (most recent call last):
Jun  2 18:51:05 freenas freenas[48012]:   File "/usr/local/www/freenasUI/common/system.py", line 179, in send_mail
Jun  2 18:51:05 freenas freenas[48012]:     local_hostname=local_hostname)
Jun  2 18:51:05 freenas freenas[48012]:   File "/usr/local/lib/python2.7/smtplib.py", line 251, in __init__
Jun  2 18:51:05 freenas freenas[48012]:     (code, msg) = self.connect(host, port)
Jun  2 18:51:05 freenas freenas[48012]:   File "/usr/local/lib/python2.7/smtplib.py", line 312, in connect
Jun  2 18:51:05 freenas freenas[48012]:     (code, msg) = self.getreply()
Jun  2 18:51:05 freenas freenas[48012]:   File "/usr/local/lib/python2.7/smtplib.py", line 360, in getreply
Jun  2 18:51:05 freenas freenas[48012]:     + str(e))
Jun  2 18:51:05 freenas freenas[48012]: SMTPServerDisconnected: Connection unexpectedly closed: timed out
Jun  2 18:52:04 freenas freenas[2530]: Traceback (most recent call last):
Jun  2 18:52:04 freenas freenas[2530]:   File "/usr/local/www/freenasUI/../freenasUI/common/system.py", line 179, in send_mail
Jun  2 18:52:04 freenas freenas[2530]:     local_hostname=local_hostname)
Jun  2 18:52:04 freenas freenas[2530]:   File "/usr/local/lib/python2.7/smtplib.py", line 251, in __init__
Jun  2 18:52:04 freenas freenas[2530]:     (code, msg) = self.connect(host, port)
Jun  2 18:52:04 freenas freenas[2530]:   File "/usr/local/lib/python2.7/smtplib.py", line 312, in connect
Jun  2 18:52:04 freenas freenas[2530]:     (code, msg) = self.getreply()
Jun  2 18:52:04 freenas freenas[2530]:   File "/usr/local/lib/python2.7/smtplib.py", line 360, in getreply
Jun  2 18:52:04 freenas freenas[2530]:     + str(e))
Jun  2 18:52:04 freenas freenas[2530]: SMTPServerDisconnected: Connection unexpectedly closed: timed out
Jun  2 18:52:05 freenas freenas[48109]: Traceback (most recent call last):
Jun  2 18:52:05 freenas freenas[48109]:   File "/usr/local/www/freenasUI/common/system.py", line 179, in send_mail
Jun  2 18:52:05 freenas freenas[48109]:     local_hostname=local_hostname)
Jun  2 18:52:05 freenas freenas[48109]:   File "/usr/local/lib/python2.7/smtplib.py", line 251, in __init__
Jun  2 18:52:05 freenas freenas[48109]:     (code, msg) = self.connect(host, port)
Jun  2 18:52:05 freenas freenas[48109]:   File "/usr/local/lib/python2.7/smtplib.py", line 312, in connect
Jun  2 18:52:05 freenas freenas[48109]:     (code, msg) = self.getreply()
Jun  2 18:52:05 freenas freenas[48109]:   File "/usr/local/lib/python2.7/smtplib.py", line 360, in getreply
Jun  2 18:52:05 freenas freenas[48109]:     + str(e))
Jun  2 18:52:05 freenas freenas[48109]: SMTPServerDisconnected: Connection unexpectedly closed: timed out
Jun  2 18:53:05 freenas freenas[48225]: Traceback (most recent call last):
Jun  2 18:53:05 freenas freenas[48225]:   File "/usr/local/www/freenasUI/common/system.py", line 179, in send_mail
Jun  2 18:53:05 freenas freenas[48225]:     local_hostname=local_hostname)
Jun  2 18:53:05 freenas freenas[48225]:   File "/usr/local/lib/python2.7/smtplib.py", line 251, in __init__
Jun  2 18:53:05 freenas freenas[48225]:     (code, msg) = self.connect(host, port)
Jun  2 18:53:05 freenas freenas[48225]:   File "/usr/local/lib/python2.7/smtplib.py", line 312, in connect
Jun  2 18:53:05 freenas freenas[48225]:     (code, msg) = self.getreply()
Jun  2 18:53:05 freenas freenas[48225]:   File "/usr/local/lib/python2.7/smtplib.py", line 360, in getreply
Jun  2 18:53:05 freenas freenas[48225]:     + str(e))
Jun  2 18:53:05 freenas freenas[48225]: SMTPServerDisconnected: Connection unexpectedly closed: timed out
Jun  2 18:53:59 freenas freenas[2530]: Traceback (most recent call last):
Jun  2 18:53:59 freenas freenas[2530]:   File "/usr/local/www/freenasUI/../freenasUI/common/system.py", line 179, in send_mail
Jun  2 18:53:59 freenas freenas[2530]:     local_hostname=local_hostname)
Jun  2 18:53:59 freenas freenas[2530]:   File "/usr/local/lib/python2.7/smtplib.py", line 251, in __init__
Jun  2 18:53:59 freenas freenas[2530]:     (code, msg) = self.connect(host, port)
Jun  2 18:53:59 freenas freenas[2530]:   File "/usr/local/lib/python2.7/smtplib.py", line 312, in connect
Jun  2 18:53:59 freenas freenas[2530]:     (code, msg) = self.getreply()
Jun  2 18:53:59 freenas freenas[2530]:   File "/usr/local/lib/python2.7/smtplib.py", line 360, in getreply
Jun  2 18:53:59 freenas freenas[2530]:     + str(e))
Jun  2 18:53:59 freenas freenas[2530]: SMTPServerDisconnected: Connection unexpectedly closed: timed out
Jun  2 18:54:05 freenas freenas[48322]: Traceback (most recent call last):
Jun  2 18:54:05 freenas freenas[48322]:   File "/usr/local/www/freenasUI/common/system.py", line 179, in send_mail
Jun  2 18:54:05 freenas freenas[48322]:     local_hostname=local_hostname)
Jun  2 18:54:05 freenas freenas[48322]:   File "/usr/local/lib/python2.7/smtplib.py", line 251, in __init__
Jun  2 18:54:05 freenas freenas[48322]:     (code, msg) = self.connect(host, port)
Jun  2 18:54:05 freenas freenas[48322]:   File "/usr/local/lib/python2.7/smtplib.py", line 312, in connect
Jun  2 18:54:05 freenas freenas[48322]:     (code, msg) = self.getreply()
Jun  2 18:54:05 freenas freenas[48322]:   File "/usr/local/lib/python2.7/smtplib.py", line 360, in getreply
Jun  2 18:54:05 freenas freenas[48322]:     + str(e))
Jun  2 18:54:05 freenas freenas[48322]: SMTPServerDisconnected: Connection unexpectedly closed: timed out
Jun  2 23:59:22 freenas smartd[2242]: Device: /dev/ada1, 16 Currently unreadable (pending) sectors
Jun  2 23:59:22 freenas smartd[2242]: Device: /dev/ada1, 16 Offline uncorrectable sectors
Jun  3 00:00:00 freenas syslog-ng[29101]: Configuration reload request received, reloading configuration;
Jun  3 00:29:22 freenas smartd[2242]: Device: /dev/ada1, 16 Currently unreadable (pending) sectors
Jun  3 00:29:22 freenas smartd[2242]: Device: /dev/ada1, 16 Offline uncorrectable sectors
Jun  3 00:59:22 freenas smartd[2242]: Device: /dev/ada1, 16 Currently unreadable (pending) sectors
Jun  3 00:59:22 freenas smartd[2242]: Device: /dev/ada1, 16 Offline uncorrectable sectors
Jun  3 01:29:22 freenas smartd[2242]: Device: /dev/ada1, 16 Currently unreadable (pending) sectors
Jun  3 01:29:22 freenas smartd[2242]: Device: /dev/ada1, 16 Offline uncorrectable sectors
Jun  3 01:59:22 freenas smartd[2242]: Device: /dev/ada1, 16 Currently unreadable (pending) sectors
Jun  3 01:59:22 freenas smartd[2242]: Device: /dev/ada1, 16 Offline uncorrectable sectors
Jun  3 02:29:23 freenas smartd[2242]: Device: /dev/ada1, 16 Currently unreadable (pending) sectors
Jun  3 02:29:23 freenas smartd[2242]: Device: /dev/ada1, 16 Offline uncorrectable sectors
Jun  3 02:59:22 freenas smartd[2242]: Device: /dev/ada1, 16 Currently unreadable (pending) sectors
Jun  3 02:59:22 freenas smartd[2242]: Device: /dev/ada1, 16 Offline uncorrectable sectors
Jun  3 03:06:08 freenas freenas[471]: Traceback (most recent call last):
Jun  3 03:06:08 freenas freenas[471]:   File "/usr/local/www/freenasUI/common/system.py", line 179, in send_mail
Jun  3 03:06:08 freenas freenas[471]:     local_hostname=local_hostname)
Jun  3 03:06:08 freenas freenas[471]:   File "/usr/local/lib/python2.7/smtplib.py", line 251, in __init__
Jun  3 03:06:08 freenas freenas[471]:     (code, msg) = self.connect(host, port)
Jun  3 03:06:08 freenas freenas[471]:   File "/usr/local/lib/python2.7/smtplib.py", line 312, in connect
Jun  3 03:06:08 freenas freenas[471]:     (code, msg) = self.getreply()
Jun  3 03:06:08 freenas freenas[471]:   File "/usr/local/lib/python2.7/smtplib.py", line 360, in getreply
Jun  3 03:06:08 freenas freenas[471]:     + str(e))
Jun  3 03:06:08 freenas freenas[471]: SMTPServerDisconnected: Connection unexpectedly closed: timed out
Jun  3 03:29:22 freenas smartd[2242]: Device: /dev/ada1, 16 Currently unreadable (pending) sectors
Jun  3 03:29:22 freenas smartd[2242]: Device: /dev/ada1, 16 Offline uncorrectable sectors
Jun  3 03:59:22 freenas smartd[2242]: Device: /dev/ada1, 16 Currently unreadable (pending) sectors
Jun  3 03:59:22 freenas smartd[2242]: Device: /dev/ada1, 16 Offline uncorrectable sectors
Jun  3 04:29:22 freenas smartd[2242]: Device: /dev/ada1, 16 Currently unreadable (pending) sectors
Jun  3 04:29:22 freenas smartd[2242]: Device: /dev/ada1, 16 Offline uncorrectable sectors
Jun  3 04:59:22 freenas smartd[2242]: Device: /dev/ada1, 16 Currently unreadable (pending) sectors
Jun  3 04:59:22 freenas smartd[2242]: Device: /dev/ada1, 16 Offline uncorrectable sectors
Jun  3 05:29:22 freenas smartd[2242]: Device: /dev/ada1, 16 Currently unreadable (pending) sectors
Jun  3 05:29:22 freenas smartd[2242]: Device: /dev/ada1, 16 Offline uncorrectable sectors
Jun  3 05:59:23 freenas smartd[2242]: Device: /dev/ada1, 16 Currently unreadable (pending) sectors
Jun  3 05:59:23 freenas smartd[2242]: Device: /dev/ada1, 16 Offline uncorrectable sectors
Jun  3 06:29:22 freenas smartd[2242]: Device: /dev/ada1, 16 Currently unreadable (pending) sectors
Jun  3 06:29:22 freenas smartd[2242]: Device: /dev/ada1, 16 Offline uncorrectable sectors
Jun  3 06:59:22 freenas smartd[2242]: Device: /dev/ada1, 16 Currently unreadable (pending) sectors
Jun  3 06:59:22 freenas smartd[2242]: Device: /dev/ada1, 16 Offline uncorrectable sectors
Jun  3 07:29:22 freenas smartd[2242]: Device: /dev/ada1, 16 Currently unreadable (pending) sectors
Jun  3 07:29:22 freenas smartd[2242]: Device: /dev/ada1, 16 Offline uncorrectable sectors
Jun  3 07:59:22 freenas smartd[2242]: Device: /dev/ada1, 16 Currently unreadable (pending) sectors
Jun  3 07:59:22 freenas smartd[2242]: Device: /dev/ada1, 16 Offline uncorrectable sectors
Jun  3 08:29:22 freenas smartd[2242]: Device: /dev/ada1, 16 Currently unreadable (pending) sectors
Jun  3 08:29:22 freenas smartd[2242]: Device: /dev/ada1, 16 Offline uncorrectable sectors
Jun  3 08:59:22 freenas smartd[2242]: Device: /dev/ada1, 16 Currently unreadable (pending) sectors
Jun  3 08:59:22 freenas smartd[2242]: Device: /dev/ada1, 16 Offline uncorrectable sectors
Jun  3 09:29:23 freenas smartd[2242]: Device: /dev/ada1, 16 Currently unreadable (pending) sectors
Jun  3 09:29:23 freenas smartd[2242]: Device: /dev/ada1, 16 Offline uncorrectable sectors
Is ada1 bad too? The raid does not show degraded (it did not show degraded last night either even thought I was told my drive ada0 was bad and needed to be replaced)
Running smartctl -q noserial -a /dev/ada1 shows:
[root@freenas] ~# smartctl -q noserial -a /dev/ada1
Device Model:     ST3000DM001-1CH166
Firmware Version: CC24
Form Factor:      3.5 inches
Local Time is:    Wed Jun  3 09:35:31 2015 EDT
                                        been run.
                                        command.
                                        power-saving mode.
  1 Raw_Read_Error_Rate     0x000f   117   099   006    Pre-fail  Always       -       162060888
  3 Spin_Up_Time            0x0003   095   094   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       99
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   072   060   030    Pre-fail  Always       -       17243254201
  9 Power_On_Hours          0x0032   077   077   000    Old_age   Always       -       20744
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       100
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0 0 0
189 High_Fly_Writes         0x003a   096   096   000    Old_age   Always       -       4
190 Airflow_Temperature_Cel 0x0022   067   059   045    Old_age   Always       -       33 (Min/Max 18/40)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       92
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       1159
194 Temperature_Celsius     0x0022   033   041   000    Old_age   Always       -       33 (0 18 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       16
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       16
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       20584h+16m+32.047s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       24270978942
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       44142737398
No Errors Logged
[root@freenas] ~#
If this appears to be bad I can get another drive and replace ada1. Is that the case? Thanks for all of your help.
You replaced ada0, and its replacement looks just fine--though with only 14 power-on hours, there's no way you could have done adequate burn-in testing on the new drive. Yes, ada1 is showing a few bad sectors. I don't think it's critical at this point. Set up a good SMART test schedule and monitor.
frozn00
Thanks for the reply. Can you tell me what I am looking for in terms of the drive going bad and/or have bad sectors? Based on what I posted? What are you looking at that determined the first drive (ada0) needed to be replaced but this one (ada1) just needed to be watched? I want to know what to look for so I know once the threshold is reached I know the drive needs to be replaced. Thanks again!
SweetAndLow
Sweet'NASty
If it has errors it should probably be replaced but doesn't have to be. If it doesn't pass long smart tests it should definitely be replaced and that also qualifies for rma. The Reallocated_Sector_Ct is probably the largest red flag.
Robert Trevellyan
Pony Wrangler
This is my interpretation, others may differ:
The drive you replaced had a value of 63192 for attribute #5, which is sectors that had actually been remapped at some point. That's a huge number of remapped sectors and may have reached the limit of what the drive had available as spares. There were a further 1536 potentially bad sectors waiting to be remapped or recovered. The drive was toast.
Your current ada1 shows 16 potential problem sectors in attribute #s 197 and 198. These sectors may or many not end up remapped. If they do, but then everything stabilizes, the drive may be fine. However, if #s 197 and 198 continue to rise, and/or #5 starts to rise, the drive is probably going bad.
You can read more on Wikipedia.
And be sure to heed the advice to set up a proper SMART testing schedule with functioning email alerts.
