purduephotog
- Jan 14, 2013
While just sitting here (watching the load refresh) the GUI stopped responding.
Googled the error message the webpage said, and freenas, and hit this thread:
http://forums.freenas.org/threads/f...09-python-was-killed-out-of-swap-space.12755/
SSH'd in and ran dmesg-
Any idea what I suddenly did (while, err, not doing anything) to trigger this problem?
Copyright (c) 1992-2012 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 8.3-RELEASE-p6 #0 r248141M: Sun Mar 10 16:35:05 PDT 2013
root@build.ixsystems.com:/home/jpaetzel/8.3.1-RELEASE/os-base/amd64/tank/home/jpaetzel/8.3.1-RELEASE/FreeBSD/src/sys/FREENAS.amd64 amd64
Timecounter "i8254" frequency 1193182 Hz quality 0
CPU: Intel(R) Celeron(R) CPU 847 @ 1.10GHz (1097.51-MHz K8-class CPU)
Origin = "GenuineIntel" Id = 0x206a7 Family = 6 Model = 2a Stepping = 7
Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Features2=0x5bae3bf<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,x2APIC,POPCNT,TSCDLT,XSAVE>
AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM>
AMD Features2=0x1<LAHF>
TSC: P-state invariant
real memory = 8589934592 (8192 MB)
avail memory = 8181915648 (7802 MB)
ACPI APIC Table: <ALASKA A M I>
FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
FreeBSD/SMP: 1 package(s) x 2 core(s)
cpu0 (BSP): APIC ID: 0
cpu1 (AP): APIC ID: 2
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ACPI Warning: FADT (revision 5) is longer than ACPI 2.0 version, truncating length 268 to 244 (20101013/tbfadt-392)
ioapic0 <Version 2.0> irqs 0-23 on motherboard
kbd1 at kbdmux0
hpt27xx: RocketRAID 27xx controller driver v1.0 (Mar 10 2013 16:34:54)
cryptosoft0: <software crypto> on motherboard
aesni0: No AESNI support.
acpi0: <ALASKA A M I> on motherboard
acpi0: [ITHREAD]
acpi0: Power Button (fixed)
acpi0: reservation of 67, 1 (4) failed
Timecounter "ACPI-fast" frequency 3579545 Hz quality 1000
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> irq 16 at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
mfi0: <Dell PERC 6> port 0xe000-0xe0ff mem 0xf7c40000-0xf7c7ffff,0xf7c00000-0xf7c3ffff irq 16 at device 0.0 on pci1
mfi0: Using MSI
mfi0: Megaraid SAS driver Ver 4.23
mfi0: [ITHREAD]
pcib2: <ACPI PCI-PCI bridge> irq 16 at device 1.2 on pci0
pci2: <ACPI PCI bus> on pcib2
vgapci0: <VGA-compatible display> port 0xf000-0xf03f mem 0xf7800000-0xf7bfffff,0xe8000000-0xefffffff irq 16 at device 2.0 on pci0
pci0: <simple comms> at device 22.0 (no driver attached)
ehci0: <EHCI (generic) USB 2.0 controller> mem 0xf7d08000-0xf7d083ff irq 16 at device 26.0 on pci0
ehci0: [ITHREAD]
usbus0: EHCI version 1.0
usbus0: <EHCI (generic) USB 2.0 controller> on ehci0
pci0: <multimedia, HDA> at device 27.0 (no driver attached)
pcib3: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
pci3: <ACPI PCI bus> on pcib3
pcib4: <ACPI PCI-PCI bridge> irq 17 at device 28.1 on pci0
pci4: <ACPI PCI bus> on pcib4
re0: <RealTek 8168/8111 B/C/CP/D/DP/E/F PCIe Gigabit Ethernet> port 0xd000-0xd0ff mem 0xf0004000-0xf0004fff,0xf0000000-0xf0003fff irq 17 at device 0.0 on pci4
re0: Using 1 MSI-X message
re0: turning off MSI enable bit.
re0: Chip rev. 0x2c800000
re0: MAC rev. 0x00000000
miibus0: <MII bus> on re0
rgephy0: <RTL8169S/8110S/8211B media interface> PHY 1 on miibus0
rgephy0: none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow
re0: Ethernet address: b8:97:5a:29:8c:cf
re0: [ITHREAD]
ehci1: <EHCI (generic) USB 2.0 controller> mem 0xf7d07000-0xf7d073ff irq 23 at device 29.0 on pci0
ehci1: [ITHREAD]
usbus1: EHCI version 1.0
usbus1: <EHCI (generic) USB 2.0 controller> on ehci1
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
ahci0: <Intel Panther Point AHCI SATA controller> port 0xf0b0-0xf0b7,0xf0a0-0xf0a3,0xf090-0xf097,0xf080-0xf083,0xf060-0xf07f mem 0xf7d06000-0xf7d067ff irq 19 at device 31.2 on pci0
ahci0: [ITHREAD]
ahci0: AHCI v1.30 with 4 6Gbps ports, Port Multiplier not supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich0: [ITHREAD]
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich2: [ITHREAD]
ahcich4: <AHCI channel> at channel 4 on ahci0
ahcich4: [ITHREAD]
ahcich5: <AHCI channel> at channel 5 on ahci0
ahcich5: [ITHREAD]
pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
acpi_button0: <Power Button> on acpi0
acpi_tz0: <Thermal Zone> on acpi0
acpi_tz1: <Thermal Zone> on acpi0
acpi_tz2: <Thermal Zone> on acpi0
acpi_hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 900
atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0
atrtc0: Warning: Couldn't map I/O.
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart0: [FILTER]
orm0: <ISA Option ROM> at iomem 0xc0000-0xcefff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
atkbd0: [ITHREAD]
ppc0: cannot reserve I/O port range
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
est0: <Enhanced SpeedStep Frequency Control> on cpu0
p4tcc0: <CPU Frequency Thermal Control> on cpu0
coretemp1: <CPU On-Die Thermal Sensors> on cpu1
est1: <Enhanced SpeedStep Frequency Control> on cpu1
p4tcc1: <CPU Frequency Thermal Control> on cpu1
fuse4bsd: version 0.3.9-pre1, FUSE ABI 7.8
Timecounters tick every 1.000 msec
hpt27xx: no controller detected.
mfi0: 4627 (427144240s/0x0020/info) - Shutdown command received from host
mfi0: 4628 (boot + 3s/0x0020/info) - Firmware initialization started (PCI ID 0060/1000/1f0b/1028)
mfi0: 4629 (boot + 3s/0x0020/info) - Firmware version 1.22.02-0612
mfi0: 4630 (boot + 23s/0x0008/info) - Battery Present
mfi0: 4631 (boot + 23s/0x0020/info) - Controller hardware revision ID (0x0)
mfi0: 4632 (boot + 23s/0x0020/info) - Package version 6.2.0-0013
mfi0: 4633 (boot + 23s/0x0020/info) - Board Revision
mfi0: 4634 (boot + 38s/0x0002/info) - Inserted: PD 00(e0xff/s0)
GEOM_RAID5: Module loaded, version 1.1.20110927.40 (rev 00ce00e5abb4)
usbus0: 480Mbps High Speed USB v2.0
usbus1: 480Mbps High Speed USB v2.0
ugen0.1: <Intel> at usbus0
uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0
ugen1.1: <Intel> at usbus1
uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
mfid0: <MFI Logical Disk> on mfi0
mfid0: 1907200MB (3905945600 sectors) RAID volume (no label) is optimal
mfid1: <MFI Logical Disk> on mfi0
mfid1: 1907200MB (3905945600 sectors) RAID volume (no label) is optimal
mfid2: <MFI Logical Disk> on mfi0
mfid2: 1907200MB (3905945600 sectors) RAID volume 'd1' is optimal
mfid3: <MFI Logical Disk> on mfi0
mfid3: 1907200MB (3905945600 sectors) RAID volume (no label) is optimal
mfid4: <MFI Logical Disk> on mfi0
mfid4: 1907200MB (3905945600 sectors) RAID volume (no label) is optimal
mfid5: <MFI Logical Disk> on mfi0
mfid5: 1907200MB (3905945600 sectors) RAID volume (no label) is optimal
mfid6: <MFI Logical Disk> on mfi0
mfid6: 1907200MB (3905945600 sectors) RAID volume (no label) is optimal
mfid7: <MFI Logical Disk> on mfi0
mfid7: 1907200MB (3905945600 sectors) RAID volume (no label) is optimal
mfi0: MFI_DCMD_PD_LIST_QUERY failed 2
mfi0: 4635 (boot + 38s/0x0002/info) - Inserted: PD 00(e0xff/s0) Info: enclPd=ffff, scsiType=0, portMap=00, sasAddr=1221000000000000,0000000000000000
mfi0: 4636 (boot + 38s/0x0002/WARN) - PD 00(e0xff/s0) is not a certified drive
mfi0: 4637 (boot + 38s/0x0002/info) - Inserted: PD 01(e0xff/s1)
mfi0: 4638 (boot + 38s/0x0002/info) - Inserted: PD 01(e0xff/s1) Info: enclPd=ffff, scsiType=0, portMap=01, sasAddr=1221000001000000,0000000000000000
mfi0: 4639 (boot + 38s/0x0002/WARN) - PD 01(e0xff/s1) is not a certified drive
mfi0: 4640 (boot + 38s/0x0002/info) - Inserted: PD 02(e0xff/s2)
mfi0: 4641 (boot + 38s/0x0002/info) - Inserted: PD 02(e0xff/s2) Info: enclPd=ffff, scsiType=0, portMap=02, sasAddr=1221000002000000,0000000000000000
mfi0: 4642 (boot + 38s/0x0002/WARN) - PD 02(e0xff/s2) is not a certified drive
mfi0: 4643 (boot + 38s/0x0002/info) - Inserted: PD 03(e0xff/s3)
mfi0: 4644 (boot + 38s/0x0002/info) - Inserted: PD 03(e0xff/s3) Info: enclPd=ffff, scsiType=0, portMap=03, sasAddr=1221000003000000,0000000000000000
mfi0: 4645 (boot + 38s/0x0002/WARN) - PD 03(e0xff/s3) is not a certified drive
mfi0: 4646 (boot + 38s/0x0002/info) - Inserted: PD 04(e0xff/s4)
mfi0: 4647 (boot + 38s/0x0002/info) - Inserted: PD 04(e0xff/s4) Info: enclPd=ffff, scsiType=0, portMap=04, sasAddr=1221000004000000,0000000000000000
mfi0: 4648 (boot + 38s/0x0002/WARN) - PD 04(e0xff/s4) is not a certified drive
mfi0: 4649 (boot + 38s/0x0002/info) - Inserted: PD 05(e0xff/s5)
mfi0: 4650 (boot + 38s/0x0002/info) - Inserted: PD 05(e0xff/s5) Info: enclPd=ffff, scsiType=0, portMap=05, sasAddr=1221000005000000,0000000000000000
mfi0: 4651 (boot + 38s/0x0002/WARN) - PD 05(e0xff/s5) is not a certified drive
mfi0: 4652 (boot + 38s/0x0002/info) - Inserted: PD 06(e0xff/s6)
mfi0: 4653 (boot + 38s/0x0002/info) - Inserted: PD 06(e0xff/s6) Info: enclPd=ffff, scsiType=0, portMap=06, sasAddr=1221000006000000,0000000000000000
mfi0: 4654 (boot + 38s/0x0002/WARN) - PD 06(e0xff/s6) is not a certified drive
mfi0: 4655 (boot + 38s/0x0002/info) - Inserted: PD 07(e0xff/s7)
mfi0: 4656 (boot + 38s/0x0002/info) - Inserted: PD 07(e0xff/s7) Info: enclPd=ffff, scsiType=0, portMap=07, sasAddr=1221000007000000,0000000000000000
mfi0: 4657 (boot + 38s/0x0002/WARN) - PD 07(e0xff/s7) is not a certified drive
mfi0: 4658 (427155657s/0x0020/info) - Time established as 07/14/13 22:20:57; (40 seconds since power on)
uhub0: 2 ports with 2 removable, self powered
uhub1: 2 ports with 2 removable, self powered
ugen0.2: <vendor 0x8087> at usbus0
uhub2: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus0
ugen1.2: <vendor 0x8087> at usbus1
uhub3: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus1
uhub2: 4 ports with 4 removable, self powered
uhub3: 4 ports with 4 removable, self powered
ugen0.3: <SMI Corporation> at usbus0
umass0: <SMI Corporation USB DISK, class 0/0, rev 2.00/11.00, addr 3> on usbus0
mfi0: 4659 (427155705s/0x0008/info) - Battery temperature is normal
mfi0: 4660 (427155705s/0x0008/info) - Battery started charging
mfi0: 4661 (427155705s/0x0008/info) - Current capacity of the battery is above threshold
ada0 at ahcich2 bus 0 scbus1 target 0 lun 0
ada0: <WDC WD20EARX-00PASB0 51.0AB51> ATA-8 SATA 3.x device
ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
da0 at umass-sim0 bus 0 scbus4 target 0 lun 0
da0: <SMI USB DISK 1100> Removable Direct Access SCSI-0 device
da0: 40.000MB/s transfers
da0: 1912MB (3915776 512 byte sectors: 255H 63S/T 243C)
SMP: AP CPU #1 Launched!
GEOM: da0s1: geometry does not match label (16h,63s != 255h,63s).
GEOM: da0s2: geometry does not match label (16h,63s != 255h,63s).
Trying to mount root from ufs:/dev/ufs/FreeNASs2a
ZFS filesystem version 5
ZFS storage pool version 28
GEOM_ELI: Device mfid0p1.eli created.
GEOM_ELI: Encryption: AES-XTS 256
GEOM_ELI: Crypto: software
GEOM_ELI: Device mfid1p1.eli created.
GEOM_ELI: Device mfid2p1.eli created.
GEOM_ELI: Device mfid3p1.eli created.
GEOM_ELI: Device mfid4p1.eli created.
GEOM_ELI: Device mfid5p1.eli created.
GEOM_ELI: Device mfid6p1.eli created.
GEOM_ELI: Device mfid7p1.eli created.
mfi0: 4662 (427160840s/0x0008/info) - Battery charge complete
(ada0:ahcich2:0:0:0): lost device
(ada0:ahcich2:0:0:0): removing device entry
ada0 at ahcich5 bus 0 scbus3 target 0 lun 0
ada0: <WDC WD10EACS-00ZJB0 01.01B01> ATA-8 SATA 2.x device
ada0: 953869MB (1953525168 512 byte sectors: 16H 63S/T 16383C)
ada1 at ahcich2 bus 0 scbus1 target 0 lun 0
ada1: <WDC WD20EARX-00PASB0 51.0AB51> ATA-8 SATA 3.x device
ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
mfi0: 4663 (427604400s/0x0020/info) - Patrol Read started
swap zone exhausted, increase kern.maxswzone
pid 11175 (smbd), uid 1001, was killed: out of swap space
pid 11178 (smbd), uid 1001, was killed: out of swap space
pid 12440 (smbd), uid 1001, was killed: out of swap space
pid 12948 (smbd), uid 1001, was killed: out of swap space
pid 2012 (python), uid 0, was killed: out of swap space
pid 13356 (smbd), uid 1001, was killed: out of swap space
pid 2562 (python), uid 0, was killed: out of swap space
