Hi all - I'm trying to create a dataset that contains all my users private folders and then a dataset below for each user.
ie: /mnt/ZFS1/users/user1
/mnt/ZFS1/users/user2, etc.
I tried the homeusers function and had problems with users not being able to log in to their home folder, so I figured I would manually make these folders (not that many so it's not that hard).
The website documentation states I can nest datasets (dataset inside of a dataset) but I don't see any way to make that happen. Is this function coming in the next release and the website already reflects it? Or is there a way to accomplish this that I'm missing?
The only way I see to accomplish what I'm looking for now is to create a "users" volume, and then each user have a dataset under. Right? The only negative I see with this is I have to specify a volume size and I have no idea what size I want (can I change this later?)
I guess to summarize my questions:
- is there any good documentation on homeusers permissions? I searched and read everything I could find and didn't help (found several people with same issue but no real resolutions).
- can I nest my users below a main "folder" (dataset, volume, etc)? Trying to keep things organized...
- if I have to create another volume as the top level folder to be able to nest datasets below it - can I change the size later without issue?
- Is there a better way to accomplish this?
Thanks!
Thanks!
