Dataset sizes keep changing
osiala
my dataset sizes keep changing based on how much data there is on other datasets. Why is that happening?
I am using raid-z with 4 4TB HDD's.
Picture one is with temporary data written to show the issue, and picture two is with the data removed.
As you can see, the Y:, X: and W: drives are smaller in capacity when the temporary data is present.
Related:
anodos
Sambassador
TL;DR version is that that Windows Explorer GUI concepts don't work well work ZFS. Configure alerts if you want proper alerting for your dataset usage. available is correct value.
osiala
Thank you for your reply. I get the same problem when checking in macOS, but I guess that is because it is still SMB? Sorry for asking, I am completely new to TrueNAS.
anodos
Sambassador
Right. The way this stuff works is the SMB client makes a SMB2 QUERY_INFO request on the opened SMB file handle for a path with InfoType set to SMB2_0_INFO_FILESYSTEM and FileInfoClass to FileFsFullSizeInformation (MS-SMB2 Section 2.2.37). The return is documented in MS-FSCC Section 2.5.4. It contains two counters basically: "total" and "available". Client utilities present three counters "total", "used", and "available".
Used is calculated by subtracting available from total. Samba wraps around statfs(2) / statvfs(2) and generates total by summing "used" with "available". It's a trade-off with ZFS. You either get the correct amount of used and available for a path (dataset). Or you get the correct "total" and "available", but not used. We went with what is fastest (just doing the syscall).
osiala
Thanks for you detailed response.
