dealy663
- Dec 4, 2021
Hi
I just noticed that my drive enclosure with a RaidZ2 pool of 4 disks was turned off on my system. Not sure what happened, power outtage, but in reviewing the notices in TrueNas Scale I see that has been offline for almost 2 days now. I powered all 4 drives up and the GUI still said that the pool was offline. I couldn't figure out how to bring it back in the GUI, so I did a zpool import from the cmd line.
Now the pool is up but the Dataset still isn't mounted. Hopefully I didn't make things worse with zpool import. Is there a proper way to bring a pool back online and mount it via the GUI? Is the right way only via zfs command line operations?
Gosh I hope I don't have to do a restore of my offsite backup, that will take days and days.
