SOLVED Dashboard Widgets Not Loading
mjeni
Good afternoon everyone,
since i transferred my only pool to a new usb-stick, my dashboard is completely empty. I have already updated the entry under "System -> System Data Set -> System Data Pool" to the new pool, unfortunately without any improvement. The graphs under menu item "Reporting" work without any problems.
I searched the forums and found some related/similar bugs, but they are all closed, or were fixed with updates. Does anyone know how I can troubleshoot this?
Thanks in advance
Mjeni
System specs:
FreeNas 11.3-RELEASE-p9
AMD A10-4655M
16GB DDR3-1333
ARAMP1
That was happening to me multiple times on 11.3-U3.1. I upgraded to U3.2 a week or so ago and it hasn't happened yet.
mjeni
Thanks for the quick answer.
Can you tell me the command to display the exact version number?
The "uname -a" command gives me the following result:
FreeBSD freenas.local 11.3-RELEASE-p9 FreeBSD 11.3-RELEASE-p9 #0 r325575+588899735f7(HEAD): Mon Jun 1 15:04:31 EDT 2020 root@mp20.tn.ixsystems.com:/freenas-releng/freenas/_BE/objs/freenas-releng/freenas/_BE/os/sys/FreeNAS.amd64 amd64".
Under System -> Update -> Train i will find the following:
FreeNAS-11.3-STABLE - Release Train for FreeNAS 11.3 [release].
Edit: Ok i found out that i have FreeNAS-11.3-U3.2 Installed..
Edit#2: Somehow it works, i have not changed anything.
