Daily Security Run Output / READ_DMA / Command Timeout
PaddyNo
Hi Community
I'm getting the following security output all the days, but honestly, I couldn't find any reference if this could be an issue or not. The latest stable updates of v9.3 are installed.
my_freenas.local kernel log messages:
> (ada4:ata0:0:1:0): READ_DMA. ACB: c8 00 a6 e0 b0 40 00 00 00 00 01 00
> (ada4:ata0:0:1:0): CAM status: Command timeout
> (ada4:ata0:0:1:0): Retrying command
> (ada4:ata0:0:1:0): READ_DMA. ACB: c8 00 dd e1 b0 40 00 00 00 00 01 00
> (ada4:ata0:0:1:0): Retrying command​
Very appreciated if anyone could give me a hint how to interpret these messages.
Post the output of:
sas2flash -listall
smartctl -a /dev/ada4
Hint: If you've searched the forums for "command timeout" you'd probably have found 20+ threads that would tell you how to identify the problem for yourself... ;)
PaddyNo
Thank you for your hint, but I couldn't find any similar error. So let me post the output you asked:
[root@my_freenas ~]# sas2flash -listall
LSI Corporation SAS2 Flash Utility
Version 14.00.00.00 (2012.07.04)
Copyright (c) 2008-2012 LSI Corporation. All rights reserved
No LSI SAS adapters found! Limited Command Set Available!
ERROR: Command Not allowed without an adapter!
ERROR: Couldn't Create Command -listall
Exiting Program.​
[root@my_freenas ~]# smartctl -a /dev/ada4
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p5 amd64] (local build)
Model Family: SandForce Driven SSDs
Device Model: KINGSTON SV300S37A60G
Serial Number: 50026B723703F02B
LU WWN Device Id: 5 0026b7 23703f02b
Firmware Version: 505ABBF1
User Capacity: 60,022,480,896 bytes [60.0 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
ATA Version is: ATA8-ACS, ACS-2 T13/2015-D revision 3
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Fri Jan 2 02:53:45 2015 CET
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity was never started.
Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run.
Total time to complete Offline data collection: ( 0) seconds.
Offline data collection capabilities: (0x7b) SMART execute Offline immediate.
Suspend Offline collection upon new command.
Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode.
Short self-test routine recommended polling time: ( 1) minutes.
Extended self-test routinerecommended polling time: ( 48) minutes.
Conveyance self-test routine recommended polling time: ( 2) minutes.
SCT capabilities: (0x0021) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 110 110 050 Pre-fail Always - 0/33550154
5 Retired_Block_Count 0x0033 100 100 003 Pre-fail Always - 0
9 Power_On_Hours_and_Msec 0x0032 090 090 000 Old_age Always - 9409h+17m+02.930s
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 20
171 Program_Fail_Count 0x0032 000 000 000 Old_age Always - 0
172 Erase_Fail_Count 0x0032 000 000 000 Old_age Always - 0
174 Unexpect_Power_Loss_Ct 0x0030 000 000 000 Old_age Offline - 10
177 Wear_Range_Delta 0x0000 000 000 000 Old_age Offline - 0
181 Program_Fail_Count 0x0032 000 000 000 Old_age Always - 0
182 Erase_Fail_Count 0x0032 000 000 000 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
189 Airflow_Temperature_Cel 0x0000 023 066 000 Old_age Offline - 23 (Min/Max 14/66)
194 Temperature_Celsius 0x0022 023 066 000 Old_age Always - 23 (Min/Max 14/66)
195 ECC_Uncorr_Error_Count 0x001c 120 120 000 Old_age Offline - 0/33550154
196 Reallocated_Event_Count 0x0033 100 100 003 Pre-fail Always - 0
201 Unc_Soft_Read_Err_Rate 0x001c 120 120 000 Old_age Offline - 0/33550154
204 Soft_ECC_Correct_Rate 0x001c 120 120 000 Old_age Offline - 0/33550154
230 Life_Curve_Status 0x0013 100 100 000 Pre-fail Always - 100
231 SSD_Life_Left 0x0013 100 100 010 Pre-fail Always - 0
233 SandForce_Internal 0x0000 000 000 000 Old_age Offline - 167
234 SandForce_Internal 0x0032 000 000 000 Old_age Always - 37
241 Lifetime_Writes_GiB 0x0032 000 000 000 Old_age Always - 37
242 Lifetime_Reads_GiB 0x0032 000 000 000 Old_age Always - 21
SMART Error Log not supported
SMART Self-test Log not supported
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.​
I'm using the SSD-drive as the boot and os partition.
