first of all I'd like to thank you for taking the time in reading this before-hand, I appreciate your help.
I woke up this morning to find two emails, the first titled "CurrentPendingSector" with the contents:
The second titled "OfflineUncorrectableSector" with the contents:
I believe these are from S.M.A.R.T. but what I can't figure out is, what is /dev/sda? Here's a list of my drives using command.
ada4 is a secondary ssd I'm not currently using, I did plan to raid it with the other ssd for Freenas/Caching but didn't find the option for it when setting it up.
ada8 is a spare hdd I have in the system right now. I actually have 4 more 3TB drives I want to add to the system when I start running out of space. And I know the Toshiba drives aren't supposed to be 24/7 drives, but I can get them for about 50 euros tax included which make them the cheapest option for me for large amount of storage. I've only had 1 of them die on me (and not even died, it just has a bad sector) out of about 12 of them in 2 years. Well, apart from this one that is reporting bad sectors in my freenas system too.
How do I go about finding what has uncorrectable sectors, as from the very limit experience I have, /dev/sda is supposed to mean "first internal drive" or?
Here are some screenshots of the system:
Thanks a lot in advance!
Device: /dev/sda [SAT], 2 Currently unreadable (pending) sectors
Device: /dev/sda [SAT], 2 Offline uncorrectable sectors
camcontrol devlist
<TOSHIBA DT01ACA300 MX6OABB0> at scbus0 target 0 lun 0 (pass0,ada0) <TOSHIBA DT01ACA300 MX6OABB0> at scbus2 target 0 lun 0 (pass1,ada1) <TOSHIBA DT01ACA300 MX6OABB0> at scbus3 target 0 lun 0 (pass2,ada2) <Marvell Console 1.01> at scbus7 target 0 lun 0 (pass3) <Marvell Console 1.01> at scbus16 target 0 lun 0 (pass4) <KINGSTON SHSS37A120G SAFM02.H> at scbus17 target 0 lun 0 (pass5,ada3) <KINGSTON SHSS37A120G SAFM02.H> at scbus18 target 0 lun 0 (pass6,ada4) <TOSHIBA DT01ACA300 MX6OABB0> at scbus19 target 0 lun 0 (pass7,ada5) <TOSHIBA DT01ACA300 MX6OABB0> at scbus20 target 0 lun 0 (pass8,ada6) <TOSHIBA DT01ACA300 MX6OABB0> at scbus21 target 0 lun 0 (pass9,ada7) <TOSHIBA DT01ACA300 MX6OABB0> at scbus22 target 0 lun 0 (pass10,ada8) <SanDisk Cruzer Switch 1.00> at scbus25 target 0 lun 0 (pass11,da0)
