Yes, you "can". It's not the most recommended way, but it should work. Do be warned that you may have unknown consequences as a result of importing a pool from another OS.
Also keep in mind that if you do a zpool upgrade on FreeNAS you *will* lose the ability to import the pool on Linux again.
Yeah, if you don't have a backup I wouldn't recommend you move to FreeNAS in the way you are considering. Just bring your pool over to my house... j/k.
Been trying to find someone that does ZFS as root on mint 17 so I can figure out what I'm doing wrong. I desperately want to experiment with it, but there is no 'good guide' for doing it and I'm not a pro at linux bootup processes.
