Cron job for
robot381
I'm a super beginner, only set up TrueNAS a few days ago and experimenting with different options.
I have set up a NextCloud using plugin, and one of the things I wanted to achieve was an alternative to google photos.
Because setting up preview was taking a god awful time, especially since I have over 5000+ photos accumulated over 10 years, I'm trying to use "preview generator" application on NextCloud (https://github.com/rullzer/previewgenerator)
On the installation note:
  1. Install the app
  2. Enable the app
  3. Run ./occ preview:generate-all once after installation.
  4. Add a (system) cron job for ./occ preview:pre-generate
  • I run it every 10 minutes
I achieved up to No. 3 stage (well, it is currently running. It is also taking a while, but it's slowly progressing!)
But I can't figure out how to do no. 4 of the instruction.
For Clarification, it says a system cron job, but my NextCloud is running in Jail (plugin). I'm not sure if this piece of information is useful.
How do I go about setting this up?
I want to run it once a day at midnight, so I'm guessing that would be
1 0 * * *
this. but where do i use this information?
Thank you so much for your help!
Alecmascot
iocage execute
will run a command/script in the jail
taaangy234
I'm not quite understand where to perform step 3-4 on TrueNAS. :( Please help someone!!!
root@freenas[~]# jexec 13 tcsh
root@nextcloud:/ # ./occ preview:generate-all
./occ: command not found.
