CRITICAL Device: /dev/da5 [SAT], 24 Currently unreadable (pending) sectors.
JBelthoff
Greetings,
I recently saw this error in the Alerts: "Device: /dev/da5 [SAT], 24 Currently unreadable (pending) sectors."
So I ran this command: smartctl -t long /dev/da5
I waited until it finished and then ran: smartctl -a /dev/da5
The Self-test log reveals No Errors(see below).
Does that mean I can dismiss this error? Or should I continue to look further and how do I do that?
# 1  Short offline       Completed without error       00%     32606         -
# 2  Extended offline    Completed without error       00%     32586         -
# 3  Short offline       Completed without error       00%     32558         -
# 4  Short offline       Completed without error       00%     32534         -
# 5  Extended offline    Completed without error       00%     32534         -
# 6  Short offline       Completed without error       00%     32486         -
# 7  Short offline       Completed without error       00%     32462         -
# 8  Short offline       Completed without error       00%     32438         -
# 9  Extended offline    Completed without error       00%     32418         -
#10  Short offline       Completed without error       00%     32390         -
#11  Short offline       Completed without error       00%     32366         -
#12  Short offline       Completed without error       00%     32342         -
#13  Short offline       Completed without error       00%     32318         -
#14  Short offline       Completed without error       00%     32294         -
#15  Short offline       Completed without error       00%     32270         -
#16  Extended offline    Completed without error       00%     32250         -
#17  Short offline       Completed without error       00%     32222         -
#18  Short offline       Completed without error       00%     32198         -
#19  Short offline       Completed without error       00%     32174         -
#20  Short offline       Completed without error       00%     32150         -
#21  Short offline       Completed without error       00%     32126         -
NugentS
Where are the rest of the stats?
JBelthoff
The full results of smartctl -a /dev/da5 are:
smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p11 amd64] (local build)
Model Family:     HGST Deskstar NAS
Device Model:     HGST HDN728080ALE604
Serial Number:    R6GSEA2Y
LU WWN Device Id: 5 000cca 263caa68e
Firmware Version: A4GNW91X
User Capacity:    8,001,563,222,016 bytes [8.00 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Thu Apr 28 14:03:59 2022 EDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  101) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        (1284) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000b   100   100   016    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0005   132   132   054    Pre-fail  Offline      -       112
  3 Spin_Up_Time            0x0007   158   158   024    Pre-fail  Always       -       450 (Average 383)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       53
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000b   100   100   067    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   128   128   020    Pre-fail  Offline      -       18
  9 Power_On_Hours          0x0012   096   096   000    Old_age   Always       -       32619
 10 Spin_Retry_Count        0x0013   100   100   060    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       53
 22 Helium_Level            0x0023   100   100   025    Pre-fail  Always       -       100
192 Power-Off_Retract_Count 0x0032   096   096   000    Old_age   Always       -       5182
193 Load_Cycle_Count        0x0012   096   096   000    Old_age   Always       -       5182
194 Temperature_Celsius     0x0002   162   162   000    Old_age   Always       -       37 (Min/Max 16/48)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       40
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
NugentS
That drive has 3.7 years on it.
I would replace it in the array with a new one. Then badblocks that drive with "-wsvb 4096" and see what happens. If it fails then warranty return (if possible) / RMA or throw it away. OR if it passes a long test smart test after badblocks completes then keep it as a spare.
ChrisRJ
When I get this kind of error I don't even bother with any further diagnosis. I replace it immediately. These days, in contrast to around 1990, drives have quite some capabilities to "cover up" internal errors up to a point. When 1 error shows up (and you have 24) it means that a ton of things has gone wrong already.
and you have 24
Actually, it's 40 now.
@JBelthoff, when you first got the notification, your drive had 24 suspicious sectors. The long SMART test increased that number to 40. That's not a good sign. I agree it's time to replace the disk.
NugentS
I didn't spot the 40.
Definately replace - is it under warranty?
